Zabbix SNMP Macro not working
  • Paradice
    • Mar 2020
    • 16
    Hey guys,
    i got an issue with my Zabbix after upgrading it to Version 5.0.1.
    my Macro {$SNMP_COMMUNITY} doesn't get replaced with the value in my Macro and SNMP sends "{$SNMP_COMMUNITY}" instead.
    Output of tcpdump on Zabbix-Server:
    zabbix.zynaptiq.internal.55283 > 10.79.1.10.snmp: [bad udp cksum 0x1747 -> 0xcac1!] { SNMPv2c C="{$SNMP_COMMUNITY}" { GetRequest(28) R=1620971974 system.sysName.0 } }
    You can find in the Attachments following Informations:
    1. A Screenshot of the Macro site
Name:	Screen Shot 2020-08-26 at 14.37.41.png
    2. A Screenshot of the SNMP Setting for my host
Name:	Screen Shot 2020-08-26 at 14.39.34.png
    Am i doing something wrong?
    Thanks in Advance!
  • dimir
    Zabbix developer
    • Apr 2011
    • 1080
    Did you hit this one? https://support.zabbix.com/browse/ZBX-17877
    If not, is this global or host/template macro?
    Another thing to consider is upgrading to the latest version which is 5.0.3 .
    • elmorekevin
      • Feb 2018
      • 15
      I have the same issue. Our Global SNMP Community Macro no longer seems to work at all. I can get host to start polling SNMP by typing out the community string instead of the macro, then waiting a few minutes. Until then, SNMP status is Red.
      I did review the release notes, and there were some macro related issues fixed, but maybe this particular bug has gotten past the recent updates.
