Templates and Host Interfaces
  • Wigmund
    • Jan 2020
    • 16
    When assigning Templates to a host is it not possible to specify which host interface you want the template items to be assigned to? Is there a way of doing this via the API or is it something needs to be done separately (afterwards) or am I taking the wrong approach?
    I have an ESXi Host which I want to monitor at the Hardware level (iDRAC) and Software level (ESXi) with two separate interfaces (IP Addresses) and want to assign a Template to each interface. Doable or should I be creating two Hosts?
    The configuration is all done via config files and the API atm.
  • Wigmund
    • Jan 2020
    • 16
    Currently on Zabbix 4.4.7 (but in the process of migrating to 5) if that has any relevance
    • dimir
      Zabbix developer
      • Apr 2011
      • 1080
      I'm not sure about the whole case but you definitely can not assign a template to a host interface. Only one same template can be linked to a host at a time, so if you really need that the only way is 2 hosts. But I think someone that has better vmware monitoring expertise could help here.
