Zabbix doesn't work
  • vsmjoao
    • Oct 2020
    • 21
    Zabbix doesn't work
    Hi guy, I'm John.
    I'm trying to configure the Zabbix server but I'm not getting it. The web interface shows that the server isn't working on port 10051.
    When I enter the command "systemctl status zabbix-server" it returns this error message:
    [root@zabbix ~]# systemctl status zabbix-server.service
    ● zabbix-server.service - Zabbix Server
    Loaded: loaded (/usr/lib/systemd/system/zabbix-server.service; enabled; vendor pres>
    Active: active (running) since Mon 2020-10-05 09:54:18 -03; 22s ago
    Process: 17747 ExecStop=/bin/kill -SIGTERM $MAINPID (code=exited, status=1/FAILURE)
    Process: 17758 ExecStart=/usr/sbin/zabbix_server -c $CONFFILE (code=exited, status=0>
    Main PID: 17760 (zabbix_server)
    Tasks: 47 (limit: 23815)
    Memory: 50.5M
    CGroup: /system.slice/zabbix-server.service
    ├─17760 /usr/sbin/zabbix_server -c /etc/zabbix/zabbix_server.conf
    ├─17761 /usr/sbin/zabbix_server: configuration syncer [synced configuration>
    ├─17762 /usr/sbin/zabbix_server: housekeeper [startup idle for 30 minutes]
    ├─17763 /usr/sbin/zabbix_server: timer #1 [updated 0 hosts, suppressed 0 ev>
    ├─17764 /usr/sbin/zabbix_server: http poller #1 [got 0 values in 0.001025 s>
    ├─17765 /usr/sbin/zabbix_server: discoverer #1 [processed 0 rules in 0.0029>
    ├─17766 /usr/sbin/zabbix_server: history syncer #1 [processed 0 values, 0 t>
    ├─17767 /usr/sbin/zabbix_server: history syncer #2 [processed 0 values, 0 t>
    ├─17768 /usr/sbin/zabbix_server: history syncer #3 [processed 0 values, 0 t>
    ├─17769 /usr/sbin/zabbix_server: history syncer #4 [processed 0 values, 0 t>
    ├─17770 /usr/sbin/zabbix_server: escalator #1 [processed 0 escalations in 0>
    ├─17771 /usr/sbin/zabbix_server: proxy poller #1 [exchanged data with 0 pro>
    ├─17772 /usr/sbin/zabbix_server: self-monitoring [processed data in 0.00008>
    ├─17773 /usr/sbin/zabbix_server: task manager [processed 0 task(s) in 0.000>
    ├─17774 /usr/sbin/zabbix_server: poller #1 [got 0 values in 0.000199 sec, g>
    ├─17775 /usr/sbin/zabbix_server: poller #2 [got 0 values in 0.000592 sec, g>
    ├─17776 /usr/sbin/zabbix_server: poller #3 [got 0 values in 0.000042 sec, g>
    ├─17777 /usr/sbin/zabbix_server: poller #4 [got 0 values in 0.000068 sec, g>
    ├─17778 /usr/sbin/zabbix_server: poller #5 [got 0 values in 0.000045 sec, g>
    ├─17779 /usr/sbin/zabbix_server: unreachable poller #1 [got 0 values in 0.0>
    ├─17780 /usr/sbin/zabbix_server: trapper #1 [processed data in 0.000000 sec>
    ├─17781 /usr/sbin/zabbix_server: trapper #2 [processed data in 0.000000 sec>
    ├─17782 /usr/sbin/zabbix_server: trapper #3 [processed data in 0.000000 sec>
    ├─17783 /usr/sbin/zabbix_server: trapper #4 [processed data in 0.000000 sec>
    ├─17784 /usr/sbin/zabbix_server: trapper #5 [processed data in 0.000000 sec>
    ├─17785 /usr/sbin/zabbix_server: icmp pinger #1 [got 0 values in 0.000196 s>
    ├─17787 /usr/sbin/zabbix_server: icmp pinger #2 [got 0 values in 0.000061 s>
    ├─17788 /usr/sbin/zabbix_server: icmp pinger #3 [got 0 values in 0.000191 s>
    ├─17789 /usr/sbin/zabbix_server: icmp pinger #4 [got 0 values in 0.000052 s>
    ├─17790 /usr/sbin/zabbix_server: icmp pinger #5 [got 0 values in 0.000073 s>
    ├─17791 /usr/sbin/zabbix_server: icmp pinger #6 [got 0 values in 0.000033 s>
    ├─17792 /usr/sbin/zabbix_server: icmp pinger #7 [got 0 values in 0.000034 s>
    ├─17794 /usr/sbin/zabbix_server: icmp pinger #8 [got 0 values in 0.000177 s>
    ├─17795 /usr/sbin/zabbix_server: icmp pinger #9 [got 0 values in 0.000039 s>
    ├─17796 /usr/sbin/zabbix_server: icmp pinger #10 [got 0 values in 0.000067 >
    ├─17798 /usr/sbin/zabbix_server: alert manager #1 [sent 0, failed 0 alerts,>
    ├─17799 /usr/sbin/zabbix_server: alerter [connecting to the database]
    ├─17801 /usr/sbin/zabbix_server: alerter [connecting to the database]
    ├─17802 /usr/sbin/zabbix_server: alerter [connecting to the database]
    ├─17803 /usr/sbin/zabbix_server: preprocessing manager #1 [queued 0, proces>
    ├─17804 /usr/sbin/zabbix_server: preprocessing worker #1 starting
    ├─17805 /usr/sbin/zabbix_server: preprocessing worker #2 starting
    ├─17807 /usr/sbin/zabbix_server: preprocessing worker #3 starting
    ├─17809 /usr/sbin/zabbix_server: lld manager #1 [processed 0 LLD rules duri>
    ├─17810 /usr/sbin/zabbix_server: lld worker [connecting to the database]
    ├─17811 /usr/sbin/zabbix_server: lld worker [connecting to the database]
    └─17812 /usr/sbin/zabbix_server -c /etc/zabbix/zabbix_server.conf
    Oct 05 09:54:18 zabbix.intranet systemd[1]: Starting Zabbix Server...
    Oct 05 09:54:18 zabbix.intranet systemd[1]: zabbix-server.service: Supervising process>
    Oct 05 09:54:18 zabbix.intranet systemd[1]: Started Zabbix Server.
    How to solve this problem?
    I'm using Centos 8 and Zabbix 5.
  • tim.mooney
    • Dec 2012
    • 1436
    Look in the zabbix_serverd.log file, which is probably in /var/log/zabbix/ to see if there are any clues to what the problem might be.
    • vsmjoao
      • Oct 2020
      • 21
      I managed to solve using the command: setsebool -P httpd_can_connect_zabbix = 1. Thx!
