Zabbix 5.2.0 Not starting on Raspian
  • obasigeorge
    • Apr 2016
    After upgrading from 5.0.5 to 5.2.0 I acquired the following error from the zabbix_server logs.
    1853:20201029:112218.582 Starting Zabbix Server. Zabbix 5.2.0 (revision bcf99fb248).
    1853:20201029:112218.582 ****** Enabled features ******
    1853:20201029:112218.582 SNMP monitoring: YES
    1853:20201029:112218.582 IPMI monitoring: YES
    1853:20201029:112218.582 Web monitoring: YES
    1853:20201029:112218.582 VMware monitoring: YES
    1853:20201029:112218.582 SMTP authentication: YES
    1853:20201029:112218.583 ODBC: YES
    1853:20201029:112218.583 SSH support: YES
    1853:20201029:112218.583 IPv6 support: YES
    1853:20201029:112218.583 TLS support: YES
    1853:20201029:112218.583 ******************************
    1853:20201029:112218.583 using configuration file: /etc/zabbix/zabbix_server.conf
    1853:20201029:112218.706 current database version (mandatory/optional): 05010043/05010043
    1853:20201029:112218.706 required mandatory version: 05020000
    1853:20201029:112218.706 starting automatic database upgrade
    1853:20201029:112218.732 Got signal [signal:11(SIGSEGV),reason:1,refaddr:0x2400000]. Crashing ...
    1853:20201029:112218.732 ====== Fatal information: ======
    1853:20201029:112218.732 program counter not available for this architecture
    1853:20201029:112218.732 === Registers: ===
    1853:20201029:112218.732 register dump not available for this architecture
    1853:20201029:112218.732 === Backtrace: ===
    1853:20201029:112218.733 === Memory map: ===
    1853:20201029:112218.733 004e3000-0083b000 r-xp 00000000 b3:02 1604 /usr/sbin/zabbix_server
    1853:20201029:112218.733 0084a000-008b7000 r--p 00357000 b3:02 1604 /usr/sbin/zabbix_server
    1853:20201029:112218.733 008b7000-008c2000 rw-p 003c4000 b3:02 1604 /usr/sbin/zabbix_server
    1853:20201029:112218.733 008c2000-008cc000 rw-p 00000000 00:00 0
    1853:20201029:112218.734 02448000-02469000 rw-p 00000000 00:00 0 [heap]
    1853:20201029:112218.734 02469000-024bb000 rw-p 00000000 00:00 0 [heap]
    1853:20201029:112218.734 6f2f8000-6f301000 r-xp 00000000 b3:02 1671 /lib/arm-linux-gnueabihf/libnss_files-2.28.so
    1853:20201029:112218.734 6f301000-6f311000 ---p 00009000 b3:02 1671 /lib/arm-linux-gnueabihf/libnss_files-2.28.so
    1853:20201029:112218.734 6f311000-6f312000 r--p 00009000 b3:02 1671 /lib/arm-linux-gnueabihf/libnss_files-2.28.so
    1853:20201029:112218.734 6f312000-6f313000 rw-p 0000a000 b3:02 1671 /lib/arm-linux-gnueabihf/libnss_files-2.28.so
    1853:20201029:112218.734 6f313000-6f319000 rw-p 00000000 00:00 0
    1853:20201029:112218.734 6f321000-6fb21000 rw-s 00000000 00:01 98353 /SYSV00000000 (deleted)
    1853:20201029:112218.734 6fb21000-71b21000 rw-s 00000000 00:01 98352 /SYSV00000000 (deleted)
    1853:20201029:112218.735 71b21000-72321000 rw-s 00000000 00:01 98350 /SYSV00000000 (deleted)
    1853:20201029:112218.735 72321000-72721000 rw-s 00000000 00:01 98349 /SYSV00000000 (deleted)
    1853:20201029:112218.735 72721000-72b21000 rw-s 00000000 00:01 98348 /SYSV00000000 (deleted)
    1853:20201029:112218.735 72b21000-73b21000 rw-s 00000000 00:01 98347 /SYSV00000000 (deleted)
    1853:20201029:112218.735 73b21000-73b25000 rw-p 00000000 00:00 0
    1853:20201029:112218.735 73b25000-73b3e000 r-xp 00000000 b3:02 1650 /lib/arm-linux-gnueabihf/libgpg-error.so.0.26.1
    1853:20201029:112218.735 73b3e000-73b4d000 ---p 00019000 b3:02 1650 /lib/arm-linux-gnueabihf/libgpg-error.so.0.26.1
    1853:20201029:112218.735 73b4d000-73b4e000 r--p 00018000 b3:02 1650 /lib/arm-linux-gnueabihf/libgpg-error.so.0.26.1
    1853:20201029:112218.736 73b4e000-73b4f000 rw-p 00019000 b3:02 1650 /lib/arm-linux-gnueabihf/libgpg-error.so.0.26.1
    1853:20201029:112218.736 73b4f000-73b55000 r-xp 00000000 b3:02 14710 /usr/lib/arm-linux-gnueabihf/libffi.so.6.0.4
    1853:20201029:112218.736 73b55000-73b65000 ---p 00006000 b3:02 14710 /usr/lib/arm-linux-gnueabihf/libffi.so.6.0.4
    1853:20201029:112218.736 73b65000-73b66000 r--p 00006000 b3:02 14710 /usr/lib/arm-linux-gnueabihf/libffi.so.6.0.4
    1853:20201029:112218.736 73b66000-73b67000 rw-p 00007000 b3:02 14710 /usr/lib/arm-linux-gnueabihf/libffi.so.6.0.4
    1853:20201029:112218.736 73b67000-73b69000 rw-p 00000000 00:00 0
    1853:20201029:112218.736 73b69000-73c2e000 r-xp 00000000 b3:02 1649 /lib/arm-linux-gnueabihf/libgcrypt.so.20.2.4
    1853:20201029:112218.736 73c2e000-73c3e000 ---p 000c5000 b3:02 1649 /lib/arm-linux-gnueabihf/libgcrypt.so.20.2.4
    1853:20201029:112218.736 73c3e000-73c3f000 r--p 000c5000 b3:02 1649 /lib/arm-linux-gnueabihf/libgcrypt.so.20.2.4
    1853:20201029:112218.736 73c3f000-73c43000 rw-p 000c6000 b3:02 1649 /lib/arm-linux-gnueabihf/libgcrypt.so.20.2.4
    1853:20201029:112218.737 73c43000-73cab000 r-xp 00000000 b3:02 14729 /usr/lib/arm-linux-gnueabihf/libgmp.so.10.3.2
    1853:20201029:112218.737 73cab000-73cba000 ---p 00068000 b3:02 14729 /usr/lib/arm-linux-gnueabihf/libgmp.so.10.3.2
    1853:20201029:112218.737 73cba000-73cbb000 r--p 00067000 b3:02 14729 /usr/lib/arm-linux-gnueabihf/libgmp.so.10.3.2
    1853:20201029:112218.737 73cbb000-73cbc000 rw-p 00068000 b3:02 14729 /usr/lib/arm-linux-gnueabihf/libgmp.so.10.3.2
    1853:20201029:112218.737 73cbc000-73ce9000 r-xp 00000000 b3:02 14736 /usr/lib/arm-linux-gnueabihf/libhogweed.so.4.5
    1853:20201029:112218.737 73ce9000-73cf9000 ---p 0002d000 b3:02 14736 /usr/lib/arm-linux-gnueabihf/libhogweed.so.4.5
    1853:20201029:112218.737 73cf9000-73cfa000 r--p 0002d000 b3:02 14736 /usr/lib/arm-linux-gnueabihf/libhogweed.so.4.5
    1853:20201029:112218.737 73cfa000-73cfb000 rw-p 0002e000 b3:02 14736 /usr/lib/arm-linux-gnueabihf/libhogweed.so.4.5
    1853:20201029:112218.738 73cfb000-73d2e000 r-xp 00000000 b3:02 14779 /usr/lib/arm-linux-gnueabihf/libnettle.so.6.5
    1853:20201029:112218.738 73d2e000-73d3d000 ---p 00033000 b3:02 14779 /usr/lib/arm-linux-gnueabihf/libnettle.so.6.5
    1853:20201029:112218.738 73d3d000-73d3e000 r--p 00032000 b3:02 14779 /usr/lib/arm-linux-gnueabihf/libnettle.so.6.5
    1853:20201029:112218.738 73d3e000-73d3f000 rw-p 00033000 b3:02 14779 /usr/lib/arm-linux-gnueabihf/libnettle.so.6.5
    1853:20201029:112218.738 73d3f000-73d4e000 r-xp 00000000 b3:02 14821 /usr/lib/arm-linux-gnueabihf/libtasn1.so.6.5.5
    1853:20201029:112218.738 73d4e000-73d5d000 ---p 0000f000 b3:02 14821 /usr/lib/arm-linux-gnueabihf/libtasn1.so.6.5.5
    1853:20201029:112218.738 73d5d000-73d5e000 r--p 0000e000 b3:02 14821 /usr/lib/arm-linux-gnueabihf/libtasn1.so.6.5.5
    1853:20201029:112218.738 73d5e000-73d5f000 rw-p 0000f000 b3:02 14821 /usr/lib/arm-linux-gnueabihf/libtasn1.so.6.5.5
    1853:20201029:112218.738 73d5f000-73ec9000 r-xp 00000000 b3:02 14826 /usr/lib/arm-linux-gnueabihf/libunistring.so.2.1.0
    1853:20201029:112218.738 73ec9000-73ed8000 ---p 0016a000 b3:02 14826 /usr/lib/arm-linux-gnueabihf/libunistring.so.2.1.0
    1853:20201029:112218.739 73ed8000-73eda000 r--p 00169000 b3:02 14826 /usr/lib/arm-linux-gnueabihf/libunistring.so.2.1.0
    1853:20201029:112218.739 73eda000-73edb000 rw-p 0016b000 b3:02 14826 /usr/lib/arm-linux-gnueabihf/libunistring.so.2.1.0
    1853:20201029:112218.739 73edb000-73fc6000 r-xp 00000000 b3:02 14788 /usr/lib/arm-linux-gnueabihf/libp11-kit.so.0.3.0
    1853:20201029:112218.739 73fc6000-73fd5000 ---p 000eb000 b3:02 14788 /usr/lib/arm-linux-gnueabihf/libp11-kit.so.0.3.0
    1853:20201029:112218.739 73fd5000-73fdb000 r--p 000ea000 b3:02 14788 /usr/lib/arm-linux-gnueabihf/libp11-kit.so.0.3.0
    1853:20201029:112218.739 73fdb000-73fe0000 rw-p 000f0000 b3:02 14788 /usr/lib/arm-linux-gnueabihf/libp11-kit.so.0.3.0
    1853:20201029:112218.739 73fe0000-73ffc000 r-xp 00000000 b3:02 1648 /lib/arm-linux-gnueabihf/libgcc_s.so.1
    1853:20201029:112218.739 73ffc000-7400b000 ---p 0001c000 b3:02 1648 /lib/arm-linux-gnueabihf/libgcc_s.so.1
    1853:20201029:112218.739 7400b000-7400c000 r--p 0001b000 b3:02 1648 /lib/arm-linux-gnueabihf/libgcc_s.so.1
    1853:20201029:112218.740 7400c000-7400d000 rw-p 0001c000 b3:02 1648 /lib/arm-linux-gnueabihf/libgcc_s.so.1
    1853:20201029:112218.740 7400d000-7413b000 r-xp 00000000 b3:02 14819 /usr/lib/arm-linux-gnueabihf/libstdc++.so.6.0.25
    1853:20201029:112218.740 7413b000-7414b000 ---p 0012e000 b3:02 14819 /usr/lib/arm-linux-gnueabihf/libstdc++.so.6.0.25
    1853:20201029:112218.740 7414b000-74150000 r--p 0012e000 b3:02 14819 /usr/lib/arm-linux-gnueabihf/libstdc++.so.6.0.25
    1853:20201029:112218.740 74150000-74152000 rw-p 00133000 b3:02 14819 /usr/lib/arm-linux-gnueabihf/libstdc++.so.6.0.25
    1853:20201029:112218.740 74152000-74156000 rw-p 00000000 00:00 0
    1853:20201029:112218.740 74156000-74159000 r-xp 00000000 b3:02 1656 /lib/arm-linux-gnueabihf/libkeyutils.so.1.8
    1853:20201029:112218.740 74159000-74168000 ---p 00003000 b3:02 1656 /lib/arm-linux-gnueabihf/libkeyutils.so.1.8
    1853:20201029:112218.740 74168000-74169000 r--p 00002000 b3:02 1656 /lib/arm-linux-gnueabihf/libkeyutils.so.1.8
    1853:20201029:112218.740 74169000-7416a000 rw-p 00003000 b3:02 1656 /lib/arm-linux-gnueabihf/libkeyutils.so.1.8
    1853:20201029:112218.741 7416a000-74173000 r-xp 00000000 b3:02 14758 /usr/lib/arm-linux-gnueabihf/libkrb5support.so.0.1
    1853:20201029:112218.741 74173000-74182000 ---p 00009000 b3:02 14758 /usr/lib/arm-linux-gnueabihf/libkrb5support.so.0.1
    1853:20201029:112218.741 74182000-74183000 r--p 00008000 b3:02 14758 /usr/lib/arm-linux-gnueabihf/libkrb5support.so.0.1
    1853:20201029:112218.741 74183000-74184000 rw-p 00009000 b3:02 14758 /usr/lib/arm-linux-gnueabihf/libkrb5support.so.0.1
    1853:20201029:112218.741 74184000-74186000 r-xp 00000000 b3:02 1636 /lib/arm-linux-gnueabihf/libcom_err.so.2.1
    1853:20201029:112218.741 74186000-74195000 ---p 00002000 b3:02 1636 /lib/arm-linux-gnueabihf/libcom_err.so.2.1
    1853:20201029:112218.741 74195000-74196000 r--p 00001000 b3:02 1636 /lib/arm-linux-gnueabihf/libcom_err.so.2.1
    1853:20201029:112218.741 74196000-74197000 rw-p 00002000 b3:02 1636 /lib/arm-linux-gnueabihf/libcom_err.so.2.1
    1853:20201029:112218.741 74197000-741c4000 r-xp 00000000 b3:02 14755 /usr/lib/arm-linux-gnueabihf/libk5crypto.so.3.1
    1853:20201029:112218.742 741c4000-741d4000 ---p 0002d000 b3:02 14755 /usr/lib/arm-linux-gnueabihf/libk5crypto.so.3.1
    1853:20201029:112218.742 741d4000-741d5000 r--p 0002d000 b3:02 14755 /usr/lib/arm-linux-gnueabihf/libk5crypto.so.3.1
    1853:20201029:112218.742 741d5000-741d6000 rw-p 0002e000 b3:02 14755 /usr/lib/arm-linux-gnueabihf/libk5crypto.so.3.1
    1853:20201029:112218.742 741d6000-741d7000 rw-p 00000000 00:00 0
    1853:20201029:112218.742 741d7000-7427a000 r-xp 00000000 b3:02 14757 /usr/lib/arm-linux-gnueabihf/libkrb5.so.3.3
    1853:20201029:112218.742 7427a000-7428a000 ---p 000a3000 b3:02 14757 /usr/lib/arm-linux-gnueabihf/libkrb5.so.3.3
    1853:20201029:112218.742 7428a000-74290000 r--p 000a3000 b3:02 14757 /usr/lib/arm-linux-gnueabihf/libkrb5.so.3.3
    1853:20201029:112218.742 74290000-74292000 rw-p 000a9000 b3:02 14757 /usr/lib/arm-linux-gnueabihf/libkrb5.so.3.3
    1853:20201029:112218.743 74292000-742a1000 r-xp 00000000 b3:02 14805 /usr/lib/arm-linux-gnueabihf/libpsl.so.5.3.1
    1853:20201029:112218.743 742a1000-742b0000 ---p 0000f000 b3:02 14805 /usr/lib/arm-linux-gnueabihf/libpsl.so.5.3.1
    1853:20201029:112218.743 742b0000-742b1000 r--p 0000e000 b3:02 14805 /usr/lib/arm-linux-gnueabihf/libpsl.so.5.3.1
    1853:20201029:112218.743 742b1000-742b2000 rw-p 0000f000 b3:02 14805 /usr/lib/arm-linux-gnueabihf/libpsl.so.5.3.1
    1853:20201029:112218.743 742b2000-742d6000 r-xp 00000000 b3:02 14817 /usr/lib/arm-linux-gnueabihf/libssh2.so.1.0.1
    1853:20201029:112218.743 742d6000-742e6000 ---p 00024000 b3:02 14817 /usr/lib/arm-linux-gnueabihf/libssh2.so.1.0.1
    1853:20201029:112218.743 742e6000-742e7000 r--p 00024000 b3:02 14817 /usr/lib/arm-linux-gnueabihf/libssh2.so.1.0.1
    1853:20201029:112218.743 742e7000-742e8000 rw-p 00025000 b3:02 14817 /usr/lib/arm-linux-gnueabihf/libssh2.so.1.0.1
    1853:20201029:112218.744 742e8000-742ff000 r-xp 00000000 b3:02 14811 /usr/lib/arm-linux-gnueabihf/librtmp.so.1
    1853:20201029:112218.744 742ff000-7430f000 ---p 00017000 b3:02 14811 /usr/lib/arm-linux-gnueabihf/librtmp.so.1
    1853:20201029:112218.744 7430f000-74310000 r--p 00017000 b3:02 14811 /usr/lib/arm-linux-gnueabihf/librtmp.so.1
    1853:20201029:112218.744 74310000-74311000 rw-p 00018000 b3:02 14811 /usr/lib/arm-linux-gnueabihf/librtmp.so.1
    1853:20201029:112218.744 74311000-7432c000 r-xp 00000000 b3:02 14743 /usr/lib/arm-linux-gnueabihf/libidn2.so.0.3.4
    1853:20201029:112218.744 7432c000-7433b000 ---p 0001b000 b3:02 14743 /usr/lib/arm-linux-gnueabihf/libidn2.so.0.3.4
    1853:20201029:112218.744 7433b000-7433c000 r--p 0001a000 b3:02 14743 /usr/lib/arm-linux-gnueabihf/libidn2.so.0.3.4
    1853:20201029:112218.744 7433c000-7433d000 rw-p 0001b000 b3:02 14743 /usr/lib/arm-linux-gnueabihf/libidn2.so.0.3.4
    1853:20201029:112218.744 7433d000-7435a000 r-xp 00000000 b3:02 14783 /usr/lib/arm-linux-gnueabihf/libnghttp2.so.14.17.1
    1853:20201029:112218.745 7435a000-74369000 ---p 0001d000 b3:02 14783 /usr/lib/arm-linux-gnueabihf/libnghttp2.so.14.17.1
    1853:20201029:112218.745 74369000-7436b000 r--p 0001c000 b3:02 14783 /usr/lib/arm-linux-gnueabihf/libnghttp2.so.14.17.1
    1853:20201029:112218.745 7436b000-7436c000 rw-p 0001e000 b3:02 14783 /usr/lib/arm-linux-gnueabihf/libnghttp2.so.14.17.1
    1853:20201029:112218.745 7436c000-744f4000 r-xp 00000000 b3:02 14730 /usr/lib/arm-linux-gnueabihf/libgnutls.so.30.23.2
    1853:20201029:112218.745 744f4000-74504000 ---p 00188000 b3:02 14730 /usr/lib/arm-linux-gnueabihf/libgnutls.so.30.23.2
    1853:20201029:112218.745 74504000-7450d000 r--p 00188000 b3:02 14730 /usr/lib/arm-linux-gnueabihf/libgnutls.so.30.23.2
    1853:20201029:112218.745 7450d000-7450e000 rw-p 00191000 b3:02 14730 /usr/lib/arm-linux-gnueabihf/libgnutls.so.30.23.2
    1853:20201029:112218.745 7450e000-7450f000 rw-p 00000000 00:00 0
    1853:20201029:112218.746 7450f000-74525000 r-xp 00000000 b3:02 14813 /usr/lib/arm-linux-gnueabihf/libsasl2.so.2.0.25
    1853:20201029:112218.746 74525000-74534000 ---p 00016000 b3:02 14813 /usr/lib/arm-linux-gnueabihf/libsasl2.so.2.0.25
    1853:20201029:112218.746 74534000-74535000 r--p 00015000 b3:02 14813 /usr/lib/arm-linux-gnueabihf/libsasl2.so.2.0.25
    1853:20201029:112218.746 74535000-74536000 rw-p 00016000 b3:02 14813 /usr/lib/arm-linux-gnueabihf/libsasl2.so.2.0.25
    1853:20201029:112218.746 74536000-7453c000 r-xp 00000000 b3:02 2995 /usr/lib/arm-linux-gnueabihf/libOpenIPMIutils.so.0.0.1
    1853:20201029:112218.746 7453c000-7454c000 ---p 00006000 b3:02 2995 /usr/lib/arm-linux-gnueabihf/libOpenIPMIutils.so.0.0.1
    1853:20201029:112218.746 7454c000-7454d000 r--p 00006000 b3:02 2995 /usr/lib/arm-linux-gnueabihf/libOpenIPMIutils.so.0.0.1
    1853:20201029:112218.746 7454d000-7454e000 rw-p 00007000 b3:02 2995 /usr/lib/arm-linux-gnueabihf/libOpenIPMIutils.so.0.0.1
    1853:20201029:112218.747 7454e000-74554000 r-xp 00000000 b3:02 1694 /lib/arm-linux-gnueabihf/librt-2.28.so
    1853:20201029:112218.747 74554000-74563000 ---p 00006000 b3:02 1694 /lib/arm-linux-gnueabihf/librt-2.28.so
    1853:20201029:112218.747 74563000-74564000 r--p 00005000 b3:02 1694 /lib/arm-linux-gnueabihf/librt-2.28.so
    1853:20201029:112218.747 74564000-74565000 rw-p 00006000 b3:02 1694 /lib/arm-linux-gnueabihf/librt-2.28.so
    1853:20201029:112218.747 74565000-7456c000 r-xp 00000000 b3:02 2972 /usr/lib/arm-linux-gnueabihf/libltdl.so.7.3.1
    1853:20201029:112218.747 7456c000-7457b000 ---p 00007000 b3:02 2972 /usr/lib/arm-linux-gnueabihf/libltdl.so.7.3.1
    1853:20201029:112218.747 7457b000-7457c000 r--p 00006000 b3:02 2972 /usr/lib/arm-linux-gnueabihf/libltdl.so.7.3.1
    1853:20201029:112218.747 7457c000-7457d000 rw-p 00007000 b3:02 2972 /usr/lib/arm-linux-gnueabihf/libltdl.so.7.3.1
    1853:20201029:112218.747 7457d000-7459d000 r-xp 00000000 b3:02 1657 /lib/arm-linux-gnueabihf/liblzma.so.5.2.4
    1853:20201029:112218.748 7459d000-745ac000 ---p 00020000 b3:02 1657 /lib/arm-linux-gnueabihf/liblzma.so.5.2.4
    1853:20201029:112218.748 745ac000-745ad000 r--p 0001f000 b3:02 1657 /lib/arm-linux-gnueabihf/liblzma.so.5.2.4
    1853:20201029:112218.748 745ad000-745ae000 rw-p 00020000 b3:02 1657 /lib/arm-linux-gnueabihf/liblzma.so.5.2.4
    1853:20201029:112218.748 745ae000-75f9a000 r-xp 00000000 b3:02 14737 /usr/lib/arm-linux-gnueabihf/libicudata.so.63.1
    1853:20201029:112218.748 75f9a000-75faa000 ---p 019ec000 b3:02 14737 /usr/lib/arm-linux-gnueabihf/libicudata.so.63.1
    1853:20201029:112218.748 75faa000-75fab000 r--p 019ec000 b3:02 14737 /usr/lib/arm-linux-gnueabihf/libicudata.so.63.1
    1853:20201029:112218.748 75fab000-75fac000 rw-p 019ed000 b3:02 14737 /usr/lib/arm-linux-gnueabihf/libicudata.so.63.1
    1853:20201029:112218.748 75fac000-76116000 r-xp 00000000 b3:02 14742 /usr/lib/arm-linux-gnueabihf/libicuuc.so.63.1
    1853:20201029:112218.749 76116000-76126000 ---p 0016a000 b3:02 14742 /usr/lib/arm-linux-gnueabihf/libicuuc.so.63.1
    1853:20201029:112218.749 76126000-76130000 r--p 0016a000 b3:02 14742 /usr/lib/arm-linux-gnueabihf/libicuuc.so.63.1
    1853:20201029:112218.749 76130000-76131000 rw-p 00174000 b3:02 14742 /usr/lib/arm-linux-gnueabihf/libicuuc.so.63.1
    1853:20201029:112218.749 76131000-76132000 rw-p 00000000 00:00 0
    1853:20201029:112218.749 76132000-76366000 r-xp 00000000 b3:02 14738 /usr/lib/arm-linux-gnueabihf/libicui18n.so.63.1
    1853:20201029:112218.749 76366000-76376000 ---p 00234000 b3:02 14738 /usr/lib/arm-linux-gnueabihf/libicui18n.so.63.1
    1853:20201029:112218.749 76376000-7637f000 r--p 00234000 b3:02 14738 /usr/lib/arm-linux-gnueabihf/libicui18n.so.63.1
    1853:20201029:112218.749 7637f000-76380000 rw-p 0023d000 b3:02 14738 /usr/lib/arm-linux-gnueabihf/libicui18n.so.63.1
    1853:20201029:112218.750 76380000-763b9000 r-xp 00000000 b3:02 14734 /usr/lib/arm-linux-gnueabihf/libgssapi_krb5.so.2.2
    1853:20201029:112218.750 763b9000-763c8000 ---p 00039000 b3:02 14734 /usr/lib/arm-linux-gnueabihf/libgssapi_krb5.so.2.2
    1853:20201029:112218.750 763c8000-763c9000 r--p 00038000 b3:02 14734 /usr/lib/arm-linux-gnueabihf/libgssapi_krb5.so.2.2
    1853:20201029:112218.750 763c9000-763ca000 rw-p 00039000 b3:02 14734 /usr/lib/arm-linux-gnueabihf/libgssapi_krb5.so.2.2
    1853:20201029:112218.750 763ca000-76502000 r-xp 00000000 b3:02 1633 /lib/arm-linux-gnueabihf/libc-2.28.so
    1853:20201029:112218.750 76502000-76512000 ---p 00138000 b3:02 1633 /lib/arm-linux-gnueabihf/libc-2.28.so
    1853:20201029:112218.750 76512000-76514000 r--p 00138000 b3:02 1633 /lib/arm-linux-gnueabihf/libc-2.28.so
    1853:20201029:112218.750 76514000-76515000 rw-p 0013a000 b3:02 1633 /lib/arm-linux-gnueabihf/libc-2.28.so
    1853:20201029:112218.750 76515000-76518000 rw-p 00000000 00:00 0
    1853:20201029:112218.750 76518000-7657e000 r-xp 00000000 b3:02 1688 /lib/arm-linux-gnueabihf/libpcre.so.3.13.3
    1853:20201029:112218.751 7657e000-7658d000 ---p 00066000 b3:02 1688 /lib/arm-linux-gnueabihf/libpcre.so.3.13.3
    1853:20201029:112218.751 7658d000-7658e000 r--p 00065000 b3:02 1688 /lib/arm-linux-gnueabihf/libpcre.so.3.13.3
    1853:20201029:112218.751 7658e000-7658f000 rw-p 00066000 b3:02 1688 /lib/arm-linux-gnueabihf/libpcre.so.3.13.3
    1853:20201029:112218.751 7658f000-765a0000 r-xp 00000000 b3:02 1693 /lib/arm-linux-gnueabihf/libresolv-2.28.so
    1853:20201029:112218.751 765a0000-765af000 ---p 00011000 b3:02 1693 /lib/arm-linux-gnueabihf/libresolv-2.28.so
    1853:20201029:112218.751 765af000-765b0000 r--p 00010000 b3:02 1693 /lib/arm-linux-gnueabihf/libresolv-2.28.so
    1853:20201029:112218.751 765b0000-765b1000 rw-p 00011000 b3:02 1693 /lib/arm-linux-gnueabihf/libresolv-2.28.so
    1853:20201029:112218.751 765b1000-765b3000 rw-p 00000000 00:00 0
    1853:20201029:112218.752 765b3000-765b5000 r-xp 00000000 b3:02 1641 /lib/arm-linux-gnueabihf/libdl-2.28.so
    1853:20201029:112218.752 765b5000-765c4000 ---p 00002000 b3:02 1641 /lib/arm-linux-gnueabihf/libdl-2.28.so
    1853:20201029:112218.752 765c4000-765c5000 r--p 00001000 b3:02 1641 /lib/arm-linux-gnueabihf/libdl-2.28.so
    1853:20201029:112218.752 765c5000-765c6000 rw-p 00002000 b3:02 1641 /lib/arm-linux-gnueabihf/libdl-2.28.so
    1853:20201029:112218.752 765c6000-76637000 r-xp 00000000 b3:02 1658 /lib/arm-linux-gnueabihf/libm-2.28.so
    1853:20201029:112218.752 76637000-76646000 ---p 00071000 b3:02 1658 /lib/arm-linux-gnueabihf/libm-2.28.so
    1853:20201029:112218.752 76646000-76647000 r--p 00070000 b3:02 1658 /lib/arm-linux-gnueabihf/libm-2.28.so
    1853:20201029:112218.752 76647000-76648000 rw-p 00071000 b3:02 1658 /lib/arm-linux-gnueabihf/libm-2.28.so
    1853:20201029:112218.752 76648000-766ba000 r-xp 00000000 b3:02 14696 /usr/lib/arm-linux-gnueabihf/libcurl.so.4.5.0
    1853:20201029:112218.753 766ba000-766c9000 ---p 00072000 b3:02 14696 /usr/lib/arm-linux-gnueabihf/libcurl.so.4.5.0
    1853:20201029:112218.753 766c9000-766cb000 r--p 00071000 b3:02 14696 /usr/lib/arm-linux-gnueabihf/libcurl.so.4.5.0
    1853:20201029:112218.753 766cb000-766cc000 rw-p 00073000 b3:02 14696 /usr/lib/arm-linux-gnueabihf/libcurl.so.4.5.0
    1853:20201029:112218.753 766cc000-766d6000 r-xp 00000000 b3:02 14760 /usr/lib/arm-linux-gnueabihf/liblber-2.4.so.2.10.10
    1853:20201029:112218.753 766d6000-766e6000 ---p 0000a000 b3:02 14760 /usr/lib/arm-linux-gnueabihf/liblber-2.4.so.2.10.10
    1853:20201029:112218.753 766e6000-766e7000 r--p 0000a000 b3:02 14760 /usr/lib/arm-linux-gnueabihf/liblber-2.4.so.2.10.10
    1853:20201029:112218.753 766e7000-766e8000 rw-p 0000b000 b3:02 14760 /usr/lib/arm-linux-gnueabihf/liblber-2.4.so.2.10.10
    1853:20201029:112218.753 766e8000-7672a000 r-xp 00000000 b3:02 14761 /usr/lib/arm-linux-gnueabihf/libldap_r-2.4.so.2.10.10
    1853:20201029:112218.753 7672a000-7673a000 ---p 00042000 b3:02 14761 /usr/lib/arm-linux-gnueabihf/libldap_r-2.4.so.2.10.10
    1853:20201029:112218.754 7673a000-7673b000 r--p 00042000 b3:02 14761 /usr/lib/arm-linux-gnueabihf/libldap_r-2.4.so.2.10.10
    1853:20201029:112218.754 7673b000-7673c000 rw-p 00043000 b3:02 14761 /usr/lib/arm-linux-gnueabihf/libldap_r-2.4.so.2.10.10
    1853:20201029:112218.754 7673c000-7673d000 rw-p 00000000 00:00 0
    1853:20201029:112218.754 7673d000-76929000 r-xp 00000000 b3:02 14695 /usr/lib/arm-linux-gnueabihf/libcrypto.so.1.1
    1853:20201029:112218.754 76929000-76938000 ---p 001ec000 b3:02 14695 /usr/lib/arm-linux-gnueabihf/libcrypto.so.1.1
    1853:20201029:112218.754 76938000-76951000 r--p 001eb000 b3:02 14695 /usr/lib/arm-linux-gnueabihf/libcrypto.so.1.1
    1853:20201029:112218.754 76951000-76952000 rw-p 00204000 b3:02 14695 /usr/lib/arm-linux-gnueabihf/libcrypto.so.1.1
    1853:20201029:112218.754 76952000-76956000 rw-p 00000000 00:00 0
    1853:20201029:112218.755 76956000-769bd000 r-xp 00000000 b3:02 14818 /usr/lib/arm-linux-gnueabihf/libssl.so.1.1
    1853:20201029:112218.755 769bd000-769cc000 ---p 00067000 b3:02 14818 /usr/lib/arm-linux-gnueabihf/libssl.so.1.1
    1853:20201029:112218.755 769cc000-769d2000 r--p 00066000 b3:02 14818 /usr/lib/arm-linux-gnueabihf/libssl.so.1.1
    1853:20201029:112218.755 769d2000-769d5000 rw-p 0006c000 b3:02 14818 /usr/lib/arm-linux-gnueabihf/libssl.so.1.1
    1853:20201029:112218.755 769d5000-76a1f000 r-xp 00000000 b3:02 14707 /usr/lib/arm-linux-gnueabihf/libevent-2.1.so.6.0.2
    1853:20201029:112218.755 76a1f000-76a2e000 ---p 0004a000 b3:02 14707 /usr/lib/arm-linux-gnueabihf/libevent-2.1.so.6.0.2
    1853:20201029:112218.755 76a2e000-76a2f000 r--p 00049000 b3:02 14707 /usr/lib/arm-linux-gnueabihf/libevent-2.1.so.6.0.2
    1853:20201029:112218.755 76a2f000-76a30000 rw-p 0004a000 b3:02 14707 /usr/lib/arm-linux-gnueabihf/libevent-2.1.so.6.0.2
    1853:20201029:112218.755 76a30000-76a47000 r-xp 00000000 b3:02 1690 /lib/arm-linux-gnueabihf/libpthread-2.28.so
    1853:20201029:112218.756 76a47000-76a56000 ---p 00017000 b3:02 1690 /lib/arm-linux-gnueabihf/libpthread-2.28.so
    1853:20201029:112218.756 76a56000-76a57000 r--p 00016000 b3:02 1690 /lib/arm-linux-gnueabihf/libpthread-2.28.so
    1853:20201029:112218.756 76a57000-76a58000 rw-p 00017000 b3:02 1690 /lib/arm-linux-gnueabihf/libpthread-2.28.so
    1853:20201029:112218.756 76a58000-76a5a000 rw-p 00000000 00:00 0
    1853:20201029:112218.756 76a5a000-76a74000 r-xp 00000000 b3:02 1713 /lib/arm-linux-gnueabihf/libz.so.1.2.11
    1853:20201029:112218.756 76a74000-76a83000 ---p 0001a000 b3:02 1713 /lib/arm-linux-gnueabihf/libz.so.1.2.11
    1853:20201029:112218.756 76a83000-76a84000 r--p 00019000 b3:02 1713 /lib/arm-linux-gnueabihf/libz.so.1.2.11
    1853:20201029:112218.756 76a84000-76a85000 rw-p 0001a000 b3:02 1713 /lib/arm-linux-gnueabihf/libz.so.1.2.11
    1853:20201029:112218.756 76a85000-76a89000 r-xp 00000000 b3:02 2992 /usr/lib/arm-linux-gnueabihf/libOpenIPMIposix.so.0.0.1
    1853:20201029:112218.757 76a89000-76a98000 ---p 00004000 b3:02 2992 /usr/lib/arm-linux-gnueabihf/libOpenIPMIposix.so.0.0.1
    1853:20201029:112218.757 76a98000-76a99000 r--p 00003000 b3:02 2992 /usr/lib/arm-linux-gnueabihf/libOpenIPMIposix.so.0.0.1
    1853:20201029:112218.757 76a99000-76a9a000 rw-p 00004000 b3:02 2992 /usr/lib/arm-linux-gnueabihf/libOpenIPMIposix.so.0.0.1
    1853:20201029:112218.757 76a9a000-76b48000 r-xp 00000000 b3:02 2990 /usr/lib/arm-linux-gnueabihf/libOpenIPMI.so.0.0.5
    1853:20201029:112218.757 76b48000-76b58000 ---p 000ae000 b3:02 2990 /usr/lib/arm-linux-gnueabihf/libOpenIPMI.so.0.0.5
    1853:20201029:112218.757 76b58000-76b64000 r--p 000ae000 b3:02 2990 /usr/lib/arm-linux-gnueabihf/libOpenIPMI.so.0.0.5
    1853:20201029:112218.757 76b64000-76b67000 rw-p 000ba000 b3:02 2990 /usr/lib/arm-linux-gnueabihf/libOpenIPMI.so.0.0.5
    1853:20201029:112218.757 76b67000-76b69000 rw-p 00000000 00:00 0
    1853:20201029:112218.757 76b69000-76bd5000 r-xp 00000000 b3:02 2338 /usr/lib/arm-linux-gnueabihf/libssh.so.4.7.4
    1853:20201029:112218.758 76bd5000-76be4000 ---p 0006c000 b3:02 2338 /usr/lib/arm-linux-gnueabihf/libssh.so.4.7.4
    1853:20201029:112218.758 76be4000-76be5000 r--p 0006b000 b3:02 2338 /usr/lib/arm-linux-gnueabihf/libssh.so.4.7.4
    1853:20201029:112218.758 76be5000-76be6000 rw-p 0006c000 b3:02 2338 /usr/lib/arm-linux-gnueabihf/libssh.so.4.7.4
    1853:20201029:112218.758 76be6000-76c7d000 r-xp 00000000 b3:02 3066 /usr/lib/arm-linux-gnueabihf/libnetsnmp.so.30.0.3
    1853:20201029:112218.758 76c7d000-76c8c000 ---p 00097000 b3:02 3066 /usr/lib/arm-linux-gnueabihf/libnetsnmp.so.30.0.3
    1853:20201029:112218.758 76c8c000-76c8e000 r--p 00096000 b3:02 3066 /usr/lib/arm-linux-gnueabihf/libnetsnmp.so.30.0.3
    1853:20201029:112218.758 76c8e000-76c8f000 rw-p 00098000 b3:02 3066 /usr/lib/arm-linux-gnueabihf/libnetsnmp.so.30.0.3
    1853:20201029:112218.758 76c8f000-76cb0000 rw-p 00000000 00:00 0
    1853:20201029:112218.759 76cb0000-76d08000 r-xp 00000000 b3:02 2978 /usr/lib/arm-linux-gnueabihf/libodbc.so.2.0.0
    1853:20201029:112218.759 76d08000-76d17000 ---p 00058000 b3:02 2978 /usr/lib/arm-linux-gnueabihf/libodbc.so.2.0.0
    1853:20201029:112218.759 76d17000-76d18000 r--p 00057000 b3:02 2978 /usr/lib/arm-linux-gnueabihf/libodbc.so.2.0.0
    1853:20201029:112218.759 76d18000-76d1c000 rw-p 00058000 b3:02 2978 /usr/lib/arm-linux-gnueabihf/libodbc.so.2.0.0
    1853:20201029:112218.759 76d1c000-76d1f000 rw-p 00000000 00:00 0
    1853:20201029:112218.759 76d1f000-76e86000 r-xp 00000000 b3:02 14834 /usr/lib/arm-linux-gnueabihf/libxml2.so.2.9.4
    1853:20201029:112218.759 76e86000-76e96000 ---p 00167000 b3:02 14834 /usr/lib/arm-linux-gnueabihf/libxml2.so.2.9.4
    1853:20201029:112218.759 76e96000-76e9a000 r--p 00167000 b3:02 14834 /usr/lib/arm-linux-gnueabihf/libxml2.so.2.9.4
    1853:20201029:112218.760 76e9a000-76e9b000 rw-p 0016b000 b3:02 14834 /usr/lib/arm-linux-gnueabihf/libxml2.so.2.9.4
    1853:20201029:112218.760 76e9b000-76e9c000 rw-p 00000000 00:00 0
    1853:20201029:112218.760 76e9c000-76ed7000 r-xp 00000000 b3:02 3007 /usr/lib/arm-linux-gnueabihf/libpq.so.5.11
    1853:20201029:112218.760 76ed7000-76ee6000 ---p 0003b000 b3:02 3007 /usr/lib/arm-linux-gnueabihf/libpq.so.5.11
    1853:20201029:112218.760 76ee6000-76ee8000 r--p 0003a000 b3:02 3007 /usr/lib/arm-linux-gnueabihf/libpq.so.5.11
    1853:20201029:112218.760 76ee8000-76ee9000 rw-p 0003c000 b3:02 3007 /usr/lib/arm-linux-gnueabihf/libpq.so.5.11
    1853:20201029:112218.760 76ee9000-76eed000 r-xp 00000000 b3:02 14672 /usr/lib/arm-linux-gnueabihf/libarmmem-v7l.so
    1853:20201029:112218.760 76eed000-76efc000 ---p 00004000 b3:02 14672 /usr/lib/arm-linux-gnueabihf/libarmmem-v7l.so
    1853:20201029:112218.760 76efc000-76efd000 r--p 00003000 b3:02 14672 /usr/lib/arm-linux-gnueabihf/libarmmem-v7l.so
    1853:20201029:112218.761 76efd000-76efe000 rw-p 00004000 b3:02 14672 /usr/lib/arm-linux-gnueabihf/libarmmem-v7l.so
    1853:20201029:112218.761 76efe000-76f1e000 r-xp 00000000 b3:02 1556 /lib/arm-linux-gnueabihf/ld-2.28.so
    1853:20201029:112218.761 76f1e000-76f24000 rw-p 00000000 00:00 0
    1853:20201029:112218.761 76f28000-76f2b000 rw-s 00000000 00:01 98351 /SYSV00000000 (deleted)
    1853:20201029:112218.761 76f2b000-76f2c000 rw-s 00000000 00:01 98346 /SYSV00000000 (deleted)
    1853:20201029:112218.761 76f2c000-76f2e000 rw-p 00000000 00:00 0
    1853:20201029:112218.761 76f2e000-76f2f000 r--p 00020000 b3:02 1556 /lib/arm-linux-gnueabihf/ld-2.28.so
    1853:20201029:112218.761 76f2f000-76f30000 rw-p 00021000 b3:02 1556 /lib/arm-linux-gnueabihf/ld-2.28.so
    1853:20201029:112218.761 7e88f000-7e8b0000 rw-p 00000000 00:00 0 [stack]
    1853:20201029:112218.761 7ee58000-7ee59000 r-xp 00000000 00:00 0 [sigpage]
    1853:20201029:112218.762 7ee59000-7ee5a000 r--p 00000000 00:00 0 [vvar]
    1853:20201029:112218.762 7ee5a000-7ee5b000 r-xp 00000000 00:00 0 [vdso]
    1853:20201029:112218.762 ffff0000-ffff1000 r-xp 00000000 00:00 0 [vectors]
    1853:20201029:112218.762 ================================
  • vso
    Zabbix developer
    • Aug 2016
    • 190
    Could you please be so kind and set DebugLevel to 5, start Zabbix server again and then attach log.
    • obasigeorge
      obasigeorge commented
      Unfortunately, I only took the dump off the server log and then reverted to 5.0.5, edited the database version table to have it running to monitor my UPS.
      I can do it over on another Pi later today.
  • markfree
    • Apr 2019
    • 875
    I believe your issue might be similar to mine.
    Previous post
    • markfree
      • Apr 2019
      • 875
      obasigeorge, are you using Raspberry OS with 64 bit architecture (aarch64)?
      • obasigeorge
        I believe I used the 32bit Raspian install, as not many things are built for the 64bit version.
    • vso
      Zabbix developer
      • Aug 2016
      • 190
      Created ticket in bug tracker:
      • Janet Kew
        • Jan 2021
        • 11
        @obasigeorge can you explain how you reverted to 5.0.5?
        I rebooted server that is hosting zabbix-server 5.0.7 and during reboot zabbix server got upgraded to version 5.2 Zabbix fronted was complaining that current version of mysql was 5020000 while it needs to be 50000 so I went to mysql and updated rows to match 50000. now fronted loads but I can't log in with any of the existing users. I didn't make any backup as I was just planning to reboot the server for kernel upgrade.
        • obasigeorge
          • Apr 2016
          To revert the database version number to the previous number expected by the application I edited the following table:
          dbversion
          update dbversion set mandatory=‘05000000’ where mandatory=‘5010043’;
          • Janet Kew
            • Jan 2021
            • 11
            I've updated db version table as you explained. But error is still present. I've checked versions of installed zabbix packages.
            [HTML]apt list --installed | grep zabbix
            zabbix-agent/unknown,now 1:5.2.7-1+ubuntu18.04 amd64 [installed]
            zabbix-frontend-php-deprecated/now 1:5.0.7-1+xenial all [installed,local]
            zabbix-get/unknown,now 1:5.2.7-1+ubuntu18.04 amd64 [installed]
            zabbix-release/unknown,unknown,now 1:5.2-1+ubuntu18.04 all [installed]
            zabbix-sender/unknown,now 1:5.2.7-1+ubuntu18.04 amd64 [installed]
            zabbix-server-mysql/unknown,now 1:5.2.7-1+ubuntu18.04 amd64 [installed][/HTML]
            Fronted-php is not getting updated nor installed:
            dpkg -i zabbix-frontend-php_5.2.7-1+ubuntu18.04_all.deb
            (Reading database ... 157553 files and directories currently installed.)
            Preparing to unpack zabbix-frontend-php_5.2.7-1+ubuntu18.04_all.deb ...
            Unpacking zabbix-frontend-php (1:5.2.7-1+ubuntu18.04) ...
            dpkg: error processing archive zabbix-frontend-php_5.2.7-1+ubuntu18.04_all.deb (--install):
            trying to overwrite '/usr/share/zabbix/actionconf.php', which is also in package zabbix-frontend-php-deprecated 1:5.0.7-1+xenial
            dpkg-deb: error: paste subprocess was killed by signal (Broken pipe)
            Errors were encountered while processing:
            • obasigeorge
              • Apr 2016
              Sorry. I didn’t realise you haven’t rolled back the application as yet. Please follow these steps:
              1. edit the apt manifest to point to version 5
              sudo -s
              vi /etc/apt/source.list.d/zabbix.repo
              change 5.2 to 5.0
              2. apt remove zabbix-*
              3. apt install zabbix-server-? zabbix-frontend-php zabbix-nginx-conf zabbix-agent
              4. Start the services
              systemctl start zabbix-server
              systemctl start zabbix-agent
              5. make sure the services start on reboot
              systemctl enable ?
              6. check for errors in the log
              tail -f /var/log/zabbix/zabbix_server.log
              • Janet Kew
                • Jan 2021
                • 11
                thank you for the explanation, I removed php-frontend 5.0 and installed it for 5.2 and my login is working now. I've updated zabbix_agent version on host machines and everything is working as before.
                thank you so much for provided info
