zabbix snmp
  • ZMS
    • Nov 2020
    • 19
    zabbix snmp
    hey
    im using snmp to track my switches
    but the the template don't monitor the cpu and memory.
    it is monitoring the network traffic but it doesn't show all the ports only half of them why is that?
  • NilsA
    • Sep 2020
    • 102
    Can you tell us some more about your configuration? What template are you using? What kinds of switches are you monitoring? Which MIB are you using for network traffic?
    • ZMS
      ZMS commented
      zabbix appliance the new one
      i made a host for the switch added the snmp port
      the templates are
      Template Module EtherLike-MIB SNMPv1
      Template Module Generic SNMPv2
      Template Module HOST-RESOURCES-MIB SNMPv1
      made a regular snmp item the OID is of the switch itself and not some port
      the problem with the network traffic solved (the problem was that the page was too small hehe)/
      but it doesnt show the cpu and memory usage
  • NilsA
    • Sep 2020
    • 102
    What do you mean by this?
    Have you checked if you can snmpget this information directly from your switch?
