Simple Check : icmppingloss is always 0 ...
  • SimpleRezo
    • Sep 2020
    • 19
    Hi
    I have created a simple template for monitoring access to an host:
    Max/min are working fine, but loss does not, it always returning 0...
    So if connection is not possible (unreachable host), i got 0 for max and min, but also for loss !
    System:
    FreeBSD 12.1, fping 5.0, Zabbix Proxy 5.0
    Process:
    zabbix_proxy: icmp pinger #1 [got 0 values in 0.000208 sec, idle 5 sec] (zabbix_proxy)
    I don't understand why i'm not getting the correct value... it used to work, I think it's probably related of a recent update (Zabbix Proxy 5 or maybe fping 5)....
  • tim.mooney
    • Dec 2012
    • 1437
    Make sure you're using the latest version of Zabbix 5.0.x, as there have been some fixes specific to fping 5.0 incorporated in very recent versions.
    • Hamardaban
      • May 2019
      • 2714
      I confirm this error. As a workaround, you can use fping 4 version again.
      • SimpleRezo
        • Sep 2020
        • 19
        OK. So I have to wait for Zabbix-Proxy 5.0.5 to come to OPNSense (current version is 5.0.4)
        (using fping4 is not really an "easy" option on OPNSense)
        • Hamardaban
          Hamardaban commented
          Just download the appropriate fping4 package and replace the executable file in the system.
          Do not use pkg or something similar.
        • SimpleRezo
          SimpleRezo commented
          Unfortunely this is not for one instance but dozens....
