Dear Zabbix Team,
Hope you will be able to help me with my issue.
Description of the issue :
I want to monitor VMware environment (Vmware 6.7) with Zabbix LTS 5.0, but unfortunattely i can' get this working.
Environment :
Error on Zabbix Server Logs :
My zabbix_server.conf
But unfortunatly the imposible to have this working.
Do you have an idea on what could be wrong ?
Best Regards, Edouard Fazenda.
Environment :
- Zabbix Server 5.0.5
- Operating System : CentOS Linux release 8.2.2004 (Core)
- VMware vCenter : 6.7.0.42300 Build : 15808844
- SSO VMware vsphere.local
- Zabbix User VMware created with Read-Only role.
1978360:20201126:163258.597 In vmware_service_update() 'vsphere.local\zabbix'@'https://xxxxxxx:443/sdk' 1978360:20201126:163258.597 In vmware_service_authenticate() 'vsphere.local\zabbix'@'https://xxxxxxx:443/sdk' 1978360:20201126:163418.605 End of vmware_service_authenticate():FAIL 1978360:20201126:163418.606 In vmware_service_update_perf_entities() 1978360:20201126:163418.606 End of vmware_service_update_perf_entities() entities:0 1978360:20201126:163418.606 End of vmware_service_update():FAIL processed:102400 bytes of data. VMwareCache memory usage (free/strpool/total): 67100296 / 248 / 67108064
### Option: StartVMwareCollectors # Number of pre-forked vmware collector instances. # StartVMwareCollectors=0 StartVMwareCollectors=5 ### Option: VMwareFrequency # How often Zabbix will connect to VMware service to obtain a new data. # VMwareFrequency=60 ### Option: VMwarePerfFrequency # How often Zabbix will connect to VMware service to obtain performance data. # VMwarePerfFrequency=60 ### Option: VMwareCacheSize # Size of VMware cache, in bytes. # Shared memory size for storing VMware data. # Only used if VMware collectors are started. # VMwareCacheSize=8M VMwareCacheSize=64M ### Option: VMwareTimeout # Specifies how many seconds vmware collector waits for response from VMware service. # VMwareTimeout=10
- I have created an HOST with Agent interface with the IP of my vCenter
- Applied the template : Template VM VMware
- Define the following macro on HOST
- {$VMWARE.URL}
- {$VMWARE.USERNAME}
- {$VMWARE.PASSWORD} of type "Secret Text"
