How monitor down/up of devices?
  • LouieBrown
    • Dec 2020
    Hello
    i want to check tatus of all devices in our network, lots of them are without agent so need alternative like just ping their ip,
    this key: icmpping essay writer
    retyrn false value lots of time, zabbix server can ping device and device can ping zabbix too but "icmpping" return 0 value to zabbix server and say device is down,
    any alternative for "icmpping" or other solution to check status of devices ?
  • LenR
    • Sep 2009
    • 1011
    Is it always the same device failing? Check the zabbix logs, zabbix uses "fping". What options are you using for the icmpping item key?
    We do this for 1000's of devices for a backup "availability only" Zabbix server we use when our main server is down for maintenance.
