"No data" in Latest data graphs, if select a time range more than 4 days
  • joec
    • May 2015
    Hi all,
    I have Zabbix 1.8.13 set up on a CentOS box working good. But for some items there is "No data" error in the Latest data graphs.
    If I choose 1h or 3h or 1d in Zoom, or drag the bar to choose a time range within 4 days, everything is fine and I can see the graphs.
    However, if I choose 1w in Zoom, or drag the bar to 5 days or more, it gives [no data] and an empty graph.
    E.g.
    Graph for May 1 to May 4 -> OK
    Graph for Apr 27 to Apr 30 -> OK
    Graph for Apr 29 to May 2 -> OK
    But, graph for Apr 27 to May 4 -> No data
    I checked there is data in Values view. There are some old threads suggested the time may be off, but that's not the case.
    Could anyone please give me a hand? Thank you and appreciate that.
  • Parasin
    • Dec 2014
    • 53
    How long do you have your Zabbix system keeping history for values and trends?
    • joec
      • May 2015
      Thank you for the hint.
      Finally figured out the trends were set to zero, hence empty in the trends/trends_uint tables.
      Since trends are hourly snapshots of min,avg,max, I recomposed the values and inserted into the tables, and everything is good now. Thanks again. Cheers.
      • aciducen1995
        aciducen1995 commented
        hey i know its long time already. may i know where did u set it? i saw my trend setting is 180d but still the graph empty when I set more than 6 days
