Template: Import Failed - Cannot read XML: (68) StartTag: invalid element name
  • pascalrossillon
    • Feb 2021
    Hi All,
    I am trying to import a template to monitor NetApp: Zabbix Share - NETAPP ONTAP 9.5
    I receive the error: Cannot import Template: Import Failed - Cannot read XML: (68) StartTag: invalid element name [Line: 3016 | Column: 71
    It seems it doesn't accept this: <> at line 3016 and colum 71
    <expression>{Template SNMP NetApp cDot:dfStatus[{#SNMPINDEX}].last()}<>2</expression>
    Anyone has an idea how to fix it?
    Best regards.
  • Hamardaban
    • May 2019
    • 2714
    Replace with " = " in the template and after importing, find this trigger and return the condition back to "<>"
    • pascalrossillon
      • Feb 2021
      Hello, thanks for your answer but where is stored the template after importing to return the condition back to <>?
      • Hamardaban
        • May 2019
        • 2714
        in the template named “Template SNMP NetApp cDot” !
        • pascalrossillon
          • Feb 2021
          thanks again for the answer but can you show me the complete walkthrough after importing? where can I change the = back to <>. I am new to zabbix
          • efostevo
            • Oct 2023
            Hi can you help mi with similar issue with template "MSSQL by ODBC"
            • Cannot read XML: (68) StartTag: invalid element name [Line: 296 | Column: 73].
            i have zabbix 6.0 LTS
            template downloaded from
            https://git.zabbix.com/projects/ZBX/...Frelease%2F6.0
            but also template for 6.4 not wroking with same issue.
            I have native yaml converted to xml
            line "296 - Columnt 73 ">"
            <expression>max(/MSSQL by ODBC/mssql.buffer_cache_hit_ratio,5m)<{$MSSQL.BUFFER_CA CHE_RATIO.MIN.CRIT}
            but still no luck.
