Full database
  • gumis_148
    • Jan 2019
    • 52
    Full database
    I have a full mysql database. How can I solve it? Can I delete old files? Do I need to extend the partition?
  • gumis_148
    • Jan 2019
    • 52
    Nobody knows? Can I delete these files?
    • Zdenek_OMNISENSUIT
      • Nov 2020
      • 55
      Hello.
      Can you add more space to /dev/sdc1?
      omnisensuit.com
      • gumis_148
        • Jan 2019
        • 52
        Originally posted by Zdenek_OMNISENSUIT
        Hello.
        omnisensuit.com
        Yes, I had no choice.
          • Nov 2020
          • 55
          Hello.
          Now try think about your templates - how often and which metrics you are collecting and how long you store this data in history and trends.
          Too often checks and too long period for history will make your db much bigger.
          (mainly be carefoul about network/storages etc)
          omnisensuit.com
          • LenR
            • Sep 2009
            • 1011
            mysql doesn't free space very well, are you partitioned? Do tables need optimized? Are you innodb file per table?
              • Nov 2020
              • 55
              Hello
              Yes, if you want to clean up and release space in MySQL/MariaDB best way is exp/imp (dump).
              So, you can change setup for item check freq, history time etc, wait some time to db will delete data internaly with housekeeper.
              Than stop app/db - export/import data and you will be ok.
              Else change db postgres+Timescale or use partitioning etc.
              But if your db is smaller than 100GB it will be no need.
              omnisensuit.com
