Zabbix proxy 5.2 for Debian 8 Jessie
  • tariver
    • Apr 2021
    Greetings!
    Trying to install proxy version 5.2 to Debian 8 Jessie. I've added repository using https://repo.zabbix.com/zabbix/5.2/d...ebian8_all.deb but it seems there is no zabbix-proxy-mysql package in this repository. The only version that apt-cache finds is 1:2.2.23+dfsg-0+deb8u1 from Debian's own repositories.
    The agent's version is 5.2 from Zabbix repositories.
    1:5.2.6-1+debian8 0
    500 http://repo.zabbix.com/zabbix/5.2/debian/ jessie/main amd64 Packages
    My question is - am I missing something? Is Zabbix proxy available for this OS? Maybe I can install Zabbix proxy from source?
    P.S. I need proxy 5.2 since it's the version of my server.
  • dimir
    Zabbix developer
    • Apr 2011
    • 1080
    For Debian 8 only agent and tools 5.2 are available. Same for CentOS 7.
    https://www.zabbix.com/download?zabb...jessie&db=&ws=
    • tariver
      • Apr 2021
      Thanks for confirmation.
      Just to be sure - is building from source also not an option?
      • dimir
        Zabbix developer
        • Apr 2011
        • 1080
        No, you can do that. You would need to install newer dependencies that are not provided by the OS. Or use backports.
        • tariver
          • Apr 2021
          Got it up and running. Even didn't have to install backports, only a couple of dependencies.
          But have a couple of question:
          1. The config file is located in /usr/local/etc/zabbix_proxy.conf Is it possible to move it to /etc/zabbix/zabbix_proxy.conf ?
          2. Where I can get a .service file for systemd? The source code only has init.d file and only for agent and server (in misc/init.d/debian)
          • dimir
            Zabbix developer
            • Apr 2011
            • 1080
            1. Should be so if you run configure with --sysconfdir=/etc .
            2. Download the source package and get them from there. You will need to install zabbix-release package and then run:
            sudo apt update
            cd /tmp
            apt source zabbix
            find zabbix*/debian -name '*.service'
            • mberthault@yahoo.fr
              • Apr 2021
              • 9
              I am currently trying to deploy a full monitoring infrastructure for a small company in France, and we chose Zabbix to do that.
              Some of the machines I need to install the proxy on, are Debian 8 machines (Jessie), and - as the answers above say - it is only possible via the sources
              But I am quite new to this, and I find it very difficult to find documentation on how to install proxy from sources, for Zabbix 5.2.
              Could you please help me by directing me to some install/config documentation about it?
              I have no preference about the Database used (mysql, postgres... all are fine to me)
              Thanks in advance.
              _Mathieu
                • Apr 2021
                • 9
                Thank you
                But I have already (quite obviously) read it, and am not quite sure of how to deal with it.
                For the packet installation, I had found many tutorials, and a lot of very detailed explainations.
                But for the source install, it is very difficult for me.
                For instance, in the official documentation, I am not sure of how to install the database (when the sql are not included in the git sources), and the .configure options confuse me...
                As I said, I am quite new to this all compiling from sources matter
                Thanks anyways
                  • Apr 2021
                  • 9
                  Great! Thanks, I did skip to git
                  Now I have all aI needed for the database.
                  Any tips for the ./configure --options?
                  I think I'll need to put the "with mysql" option, but for the other ones, well... not sure at all :/
                  Thank you, btw. This is all kinda new to me, and I feel less insecure now, but still, this is a huge step forward
                    • Apr 2021
                    • 9
                    Hi
                    Well, sorry for asking again, but...
                    ... well... I did read all that, and I thought I'd ask around here if someone knew what each of these options were.
                    I honestly was not expecting a RTFM answer...
                    Please, do believe me when I tell you that I'm trying, and that I did read all the things you tell me to read.
                    So, do you have tips, or do you know a place I could go to to find some? - a place that is not the (very dry) documentation.
                      • Apr 2021
                      • 9
                      Thanks, and sorry for my previous message, I was quite tired after all this work
                      I'll try this ASAP
                        • 4996
                        I am leaning toward the similar issue as with RH7... no available software (needed php etc versions) and thus not supported.
                        If you look at
                        Zabbix is being downloaded over 4 000 000 times every year for a reason. Download and install Zabbix for free and try it yourself!
                        then you will not get any downloadable things for server and debian 8 or 9...you can get them for deb10.
                        8 and 9...
                          • 4996
                          How about documentation...
                            • 4996
                            You read it and most obviously skipped the download section and continued to git...
                            1 DOWNLOAD THE SOURCE ARCHIVE
                            Go to the
                            Download sources from Git repository or ready-to-use Zabbix distributives
                            and download the source archive.
                            Specially downloaded source tarball from there and unpacked and verified.. schema.sql is there for mysql, oracle, postgre and sqlite3
                            find . -name schema.sql
                            ./zabbix-5.2.6/database/mysql/schema.sql
                            ./zabbix-5.2.6/database/oracle/schema.sql
                            ./zabbix-5.2.6/database/postgresql/schema.sql
                            ./zabbix-5.2.6/database/sqlite3/schema.sql
                              • 4996
                              #15
                              To see all of the supported configuration options, inside the extracted Zabbix source directory run:
                              ./configure --help
                              Choose what you need and use them.
