Zabbix proxy 5.2 for Debian 8 Jessie
    • 4996
    #16
    I know I gave you pretty much RTFM answer, but if it is your first time ever to compile anything, it is going to be a big step. You cannot really expect someone to go through all the little details of those close to 100 options you can specify for configure... This is "beauty" of running unsupported platforms, you have to go extra mile to get things you need. Those definitely need some extra work and learning.
    Most of those are for setting different features... you should at least specify, what db you are going to use,options to use different security options (ssl). Not every option there has to be used.
    If I look on a proxy startup messages ( installed from packages, not selfcompiled)
    **** Enabled features ****
    SNMP monitoring: YES
    IPMI monitoring: YES
    Web monitoring: YES
    VMware monitoring: YES
    ODBC: YES
    SSH support: YES
    IPv6 support: YES
    TLS support: YES
    So if you go and enable those, you should be fine. Depending, is that proxy going to do any vmware or ipmi or snmp things, you can leave those out, but enabling those will not do any harm also.
      • 4996
      #17
      To see all of the supported configuration options, inside the extracted Zabbix source directory run:
      ./configure --help
      Choose what you need and use them.
        • 4996
        #18
        Web monitoring: YES
        ODBC: YES
        SSH support: YES
        IPv6 support: YES
        TLS support: YES
