Zabbix - trigger problem
  • corinthe
    • Apr 2021
    Hi everyone,
    I am a newbie and I got some issues with a host (I will call it the defective host in this topic).
    I can't explain why the trigger from my template does not work. I was wondering whether you could have a solution or some documentations/forums where I could search. I have no errors in my proxy's logs, my server's logs or my agent's logs.
    To resume my situation:
    • My configuration seems to work fine. For the defective host, it runs behind a proxy and sends its monitoring data correctly. For your information : it was not working correctly in the beginning. But I have to "Execute Now" (Configuration > Hosts > "Defective Host" > Discovery Rule) the "Discovery Rule" and restart my agent and finally the monitoring data are coming correctly.
    • On all hosts, I have at least a "Template OS by Zabbix Agent" (mainly Windows OS and the defective host is Windows).
    • The triggers from Mounted filesystem discovery & Physical disks discovery template aren't working even though the conditions for triggering are met.
    If you have any idea where I could search or any other lead for my investigation, I would really appreciate.
    Thank you in advance!
    Best regards,
