Upgarde from 2.0.3 appliance to 2.4.1 appliance
  • samsaleem
    • Jul 2013
    HI,
    i have zabbix appliance in production with 2.0.3 installed, wanted to upgrade to 2.4.1 appliance,
    I tried to migrate the database, from 2.0.3 dint work is there any clear way of doing this upgrade?
    regards
    Saleem.
  • richlv
    • Oct 2005
    • 3112
    you would have to install 2.4 (preferably, 2.4.5 or the upcoming 2.4.6) and then the database upgrade should be fully automatic.
    as for packages themselves, there is no automated process for that. upgrading to later versions is supported since appliance 2.4.
    • samsaleem
      • Jul 2013
      so you are recommending a separate installation of 2.4.5 or 2.4.6 and then how i migrate the database to the new one ?
      • richlv
        • Oct 2005
        • 3112
        personally i'd probably suggest waiting for the 2.4.6 appliance, then migrating the database to it
        migrating the database - that would be the standard procedure of mysldump & then restoring it
