Compare values on graph
  • Coristo
    • Dec 2020
    Hi!
    I'd like to prepare graph, or whole screen, that compares values from the whole group.
    E.g. I've got group contains my all Virtual Machines and I need to know which ones have the highest CPU or RAM consumption.
    There is no problem to show all values using `data overview` in the `screens` section, but it's not readable enough.
    Any ideas how I can achieve this?
  • Atsushi
    • Aug 2013
    • 2028
    Try using the new graph widget on your dashboard. For example, you can view the same metrics on multiple servers on a single graph.
    • Coristo
      • Dec 2020
      I made this, but there is over 30 VMs and i it's completely unreadable :/ Click image for larger version
      • Atsushi
        • Aug 2013
        • 2028
        How did you set the host pattern when creating the graph? Did you list all the hosts?
