Hi all,
I tried to import an xml template created from Fortigate MIB using the tool found here https://github.com/Sean-Bradley/SNMP2ZABBIX and I face a problem.
When I try to import the template from Zabbix GUI, I checked all the options of "Create new" as I have a similar template already installed in Zabbix, and at the end the following error appears:
Invalid parameter "/1/mappings/7": value (value)=(0) already exists.
What is causing the problem? I already managed to import the yaml template found in https://github.com/mbdraks/fortinet-zabbix and it's fine. But with my custom made template is not working and shows me this issue.
The filesize is almost 2MB but I don't find what is causing the problem.
Appreciate any help.
Thank you!
Phil
Thank you!
Phil
