Hi everyone!
I'm new here and not very familiar with Zabbix. I already tried to find a solution for my problem, but I failed.
I tried to install Zabbix on an Ubuntu 20.04.2 LTS server with a Plesk administration. I used this tutorial.
I had no problems during the installation, everything seemed to be fine. When I installed it for the first time, I opened up ''[IP_Adress]/zabbix'' and my browser downloaded a file called ''Download" instead of opening up the frontend. I removed everything from the server and started again. The second time I only got an ''ERR_EMPTY_RESPONSE''. The DNS resolving seems to be fine though.
Does anybody have a suggestion on what I should try to make it work?
Thank you in advance!
