Zabbix 5.4 Frontend + Server on Ubuntu 16.04?
  • hc128168
    • Aug 2021
    I am trying to install them from packages.
    However, it seems like no such package according to https://www.zabbix.com/download?zabb...xenial&db=&ws= ?
    And I also ran apt to check:
    apt search zabbix | grep "5.4"
    WARNING: apt does not have a stable CLI interface. Use with caution in scripts.
    zabbix-agent/unknown,now 1:5.4.3-1+ubuntu16.04 amd64 [installed]
    zabbix-get/unknown 1:5.4.3-1+ubuntu16.04 amd64
    zabbix-release/unknown,unknown,now 1:5.4-1+ubuntu16.04 all [installed]
    zabbix-sender/unknown 1:5.4.3-1+ubuntu16.04 amd64
    Or am I missing sometihng?
  • Atsushi
    • Aug 2013
    • 2028
    Zabbix official repository does not publish frontend package for Ubuntu 16.04 of Zabbix 5.4. In particular, PHP must be 7.2.5 or later to work with Zabbix 5.4 frontend. I think the standard PHP version of Ubuntu 16.04 was 7.0, so it doesn't meet the system requirements.
    It is recommended to use 18.04 or 20.04 to run Zabbix 5.4 frontend using official Zabbix package on Ubuntu.
    • rohirrim
      • May 2020
      • 20
      Why do you try on Ubuntu 16.04? If there is no special reason, I highly recommend Ubuntu 20.04 because of LTS.
      It would be better to use this page to setup
      Zabbix is being downloaded over 4 000 000 times every year for a reason. Download and install Zabbix for free and try it yourself!
      • um3n
        • Aug 2021
        • 48
        Hey,
        you really should update your installation for security and stability reasons
        But maybe you can't update, because of compliance or compatibility reasons. So you should check the Requirements of Zabbix.
        Then you should check the packages that are available for your Ubuntu Release and also go ahead and check, if you can install the repositories from the vendors, so you are
        able to use the reduired versions of the tools.
        It could be possbile, that you need to install the packages from zabbix directly via
         dpkg -i <package>
        because the versions you are looking for are not included in the repos.
        Good luck!
        Ulli
