Template import missing items
  • markfree
    • Apr 2019
    • 875
    I have created a template for some Asus routers and, whenever I export it, some dependent items are missing.
    The template has the item "Memory WebUI Total" which is dependent on "Linux memory by Zabbix agent: Total memory" (from OOTB template).
    When I export the template, this item is not added to .yaml file.
    So, when I try to import it in another server installation, the error bellow occurs.
    Cannot find item "vm.memory.size[webui,total]" on "Asus Router by Zabbix Agent" used as the Y axis MAX value for graph "Memory WEBUI".
    Any idea why is that?
  • markfree
    • Apr 2019
    • 875
    I infered that the "Memory WebUI Total" item is not being exported because it depends on another item from another template.
    If I change the item's dependency to something different, it is exported to the .yaml file correctly.
    That seems odd and I'm not sure why it happens. For now, I could not find any documented information about that behavior.
    Any thoughts?
