Reset web front end password?
  • mightypant5
    • Nov 2021
    I somehow have managed to forget my web front end password. I suspect that I accidentally deleted/overwrote the password in my password manager. When I try to log in with the password that I believe it is set to I get an error saying: "Incorrect user name or password or account is temporarily blocked."
    I see in the documentation it says
    2.1 Credentials (login:Password)
    System:
    • appliance:zabbix
    Database:
    • root:<random>
    • zabbix:<random>
    Database passwords are randomly generated during the installation process.
    Root password is stored to /root/.my.cnf file, it is not required to input a password under the “root” account.
    Zabbix frontend:
    • Admin:zabbix
    To change the database user password it has to be changed in the following locations:
    • MySQL;
    • /etc/zabbix/zabbix_server.conf;
    • /etc/zabbix/web/zabbix.conf.php.
    None of the above Login/passwords work. Is the database password the same as the web front end password? I don't want to go through the trouble of resetting that and then further break my zabbix instance if that's not the right one. How do I reset the password?
    thanks!
  • Hamardaban
    • May 2019
    • 2714
    First of all, ask Google!! ;-) "zabbix frontend reset password"
    https://yallalabs.com/linux/zabbix-h...ut-gui-access/
    https://bobcares.com/blog/zabbix-reset-admin-password/
    etc
    • markfree
      • Apr 2019
      • 875
      Originally posted by Hamardaban
      Both of these posts sugest using:
      update users set passwd=md5('YOUR_NEW_PASSWORD') where alias='Admin';
      You should change "alias" with "username" for a more recent Zabbix Server. Like this:
      update zabbix.users set passwd=md5('YOUR_NEW_PASSWORD') where username='Admin';
      I guess "alias" was an old name for the "username" column.
    • saintsid
      • Aug 2022
      Yeah, it does not work and not looking good now with md5. How to change password now?
Name:	Screenshot 2022-08-15 101707.png
      • Jonas Lundberg
        Jonas Lundberg commented
        If anyone lands on this, the below helped me. I am running v 6.2 and the md5 doesn't work either. The password is now encryped with bcrypt so run it through bcrypt first
        Example (I used a webbased tool but) I think you can with htpasswd from apache run something like htpasswd -bnBC 10 "zabbix" password | tr -d ':\n'
        then in mysql, example:
        update zabbix.users set passwd=('$2y$10$OmrcMNBQ06h1UuaDWxCsKe9/T8qscsdgE9wcgkyafWHYoBw3i') where userid='1';
    • yonisade
      • Aug 2022
      A workaround is to set "Admin" encrypted password same as "guest" user in MySQL:
      UPDATE zabbix.users AS a
      INNER JOIN zabbix.users AS b ON b.username='guest'
      SET a.passwd = b.passwd;
      and then login into the Zabbix Web UI with "Admin" user and without a password and then change the password in the "User Settings"->"Profile" page
      • ojosaghae
        ojosaghae commented
        Thank you so much!!!
    • BBAMike
      • Dec 2022
      I just want to say that I've registered for this forum for the express purpose of thanking you for posting this workaround.
      • vishu
        vishu commented
        Hi ,For above post user name and password please
    • zabbitude
      • Mar 2023
      I just want to say that I've registered too for this forum for the express purpose of thanking you for posting this workaround
      This didn't worked exactly as expected since I've made the choice of Postgresql. So here is the command I used from psql:
      postgres=#\c zabbix
      zabbix=# UPDATE users SET passwd=(SELECT passwd FROM users WHERE username='guest') WHERE username='Admin';
      • rockandstone
        rockandstone commented
        Thank you
      • crsanjeev
        crsanjeev commented
        Thank you, zabbitude!!
        I modified the code shared by zabbitute to reset the password to default - zabbix for user Admin.
        The code is as follows:
        postgres=#\c zabbix
        zabbix=# UPDATE users SET passwd=('$2y$10$23CgexOq40If/sG46AYus.U2v82WiDfMrcqYRNoGSf6T7swAdytZS') WHERE username='Admin';
    • mircsicz
      • Oct 2020
      • 10
      I'm grateful for that hint but have to disagree with that suggestion! You'll reset every users password!!!
      and then login into the Zabbix Web UI with "Admin" user without a password and then change the password in the "User Settings"->"Profile" page
      I suggest to just update admin's passwd by running this line:​
      update zabbix.users set passwd=('$2y$10$zH.KFQELRDLKlExVq18Z.eVty9yLGL7cHM9B9vTuXX1oDTcWvYALK') where userid='1';
      This will set the passwd to 'foobar' then go ahead login and change the passwd to sth appropriate.
      BTW: I was drawn to this topic after upgrading straight from 5.0.34 to 6.0.17.
      So I googled and found this thread which gave me a first hint. I went ahead and found this on the blog. What I'm really missing here is a hint for a solution like this somewhere in the blog or the changelog...
      • mcornett6
        mcornett6 commented
        Thanks for the help!
    • crsanjeev
      • Aug 2023
      postgres=#\c zabbix
      I modified the code shared by zabbitude to reset password for Admin user to default - zabbix ($2y$10$23CgexOq40If/sG46AYus.U2v82WiDfMrcqYRNoGSf6T7swAdytZS - BCRYPT HASH)
      postgres=#\c zabbix
      zabbix=# UPDATE users SET passwd=('$2y$10$23CgexOq40If/sG46AYus.U2v82WiDfMrcqYRNoGSf6T7swAdytZS') WHERE username='Admin';​
      • BlueH2O
        • Jul 2023
        None of these methods worked for me; is there another way?
        I have reset the password in the database, and confirmed the hash matches the value I expect. I also reset the attempt_failed and attempt_clock.
        Zabbix still will not accept any login.
        • hbswzy
          • Feb 2025
          Thank you so much! I'm surprised I had to do so much digging to find this beautiful trick, cheers!
          • Dangers
            • Mar 2025
            THANK YOU SO MUCH!!!! You've saved me from a VERY disappointing night after spending hours on this and trying to figure out what's going wrong to no avail until I tried this!! You've made my night, Bless your soul!
            Just like most others I've also made an account on this forum just to thank you haha. I'll likely never login or use it again but thank you so much!
