Install zabbix proxy on ububtu 16.04
  • charsit
    • Dec 2021
    Hi, I try to install a zabbix proxy on ubuntu 16.04, I run
    # wget https://repo.zabbix.com/zabbix/5.4/u...u16.04_all.deb
    # dpkg -i zabbix-release_5.4-1+ubuntu16.04_all.deb
    but when run
    # apt update I get the following error:
    root@UD-UBUNTU-16-TMS-RB:/etc/apt/trusted.gpg.d# apt-get update
    Hit:1 http://gb.archive.ubuntu.com/ubuntu xenial InRelease
    Hit:2 http://linux.teamviewer.com/deb stable InRelease
    Get:3 http://security.ubuntu.com/ubuntu xenial-security InRelease [109 kB]
    Get:4 http://gb.archive.ubuntu.com/ubuntu xenial-updates InRelease [109 kB]
    Get:5 http://gb.archive.ubuntu.com/ubuntu xenial-backports InRelease [107 kB]
    Ign:6 https://repo.zabbix.com/zabbix/5.4/ubuntu xenial InRelease
    Ign:7 https://repo.zabbix.com/zabbix/5.4/ubuntu xenial Release
    Ign:8 https://repo.zabbix.com/zabbix/5.4/ubuntu xenial/main Sources
    Ign:9 https://repo.zabbix.com/zabbix/5.4/ubuntu xenial/main amd64 Packages
    Ign:10 https://repo.zabbix.com/zabbix/5.4/ubuntu xenial/main i386 Packages
    Ign:11 https://repo.zabbix.com/zabbix/5.4/ubuntu xenial/main all Packages
    Ign:12 https://repo.zabbix.com/zabbix/5.4/ubuntu xenial/main Translation-en_GB
    Ign:13 https://repo.zabbix.com/zabbix/5.4/ubuntu xenial/main Translation-en
    Err:8 https://repo.zabbix.com/zabbix/5.4/ubuntu xenial/main Sources
    server certificate verification failed. CAfile: /etc/ssl/certs/ca-certificates.crt CRLfile: none
    Fetched 325 kB in 38s (8,393 B/s)
    Reading package lists... Done
    W: The repository 'https://repo.zabbix.com/zabbix/5.4/ubuntu xenial Release' does not have a Release file.
    N: Data from such a repository can't be authenticated and is therefore potentially dangerous to use.
    N: See apt-secure(8) manpage for repository creation and user configuration details.
    E: Failed to fetch https://repo.zabbix.com/zabbix/5.4/ubuntu/dists/xenial/main/source/Sources server certificate verification failed. CAfile: /etc/ssl/certs/ca-certificates.crt CRLfile: none
    E: Some index files failed to download. They have been ignored, or old ones used instead.
    there is a way to resolve this?
    Thanks a lot in advance
    • 4996
    Too old ubuntu to install 5.4.
    • charsit
      charsit commented
      I need to install the proxy on 20 servers, now I install 5.4 proxy in one of them using the sources and compiling the proxy, but I want to find an easy way to do it.
    • 4996
    Understandable, but, thats what you have to deal with, if you insist on staying on unsuppoerted OS version... It is not possible to keep all needed things suppeorted on those old versions. And then you need to provide everything by yourself, compiling away...
    • charsit
      charsit commented
      Thanks for your feedback, is not under my decision to keep this OS.
      Warm regards
  • gofree
    • Dec 2017
    • 400
    perhaps use docker and zabbix proxy container ?
    • charsit
      charsit commented
      Thanks a lot for your answer, by the moment I will compile the proxy, on mid 2022 we are planning to upgrade our server's OS
