Recovery of "not supported" item with "Do not keep history" option
  • wormsik
    • Jan 2022
    Hi everyone,
    I tried to create my own template to monitor one service and used approach to gather all data in CSV to one item without a history ("Do not keep history") and then parse it in multiple Dependent items.
    However, during migration to Agent2 I forgot to move userparameter files and thus the "get" item became unsupported. And even though I fixed the mistake and now everything is collecting correctly, the item is still labelled as "not supported" with the original error. Even though this is not a crucial issue, it is quite difficult to remember which item is "falsely not supported".
    Could you please help me to "reset" the state? I was searching solution in the documentation and here, but I was not lucky. Furthermore, I have already tried disable/enable, clear history of that item, but it did not help. The only thing helped previously was to unlink & clear, but it is a bit clumsy solution as I lose the whole history.
    I attached several screenshot of items definition, host configuration with not supported status and latest data (with recent values).
    Thanks for you help!
    • 4996
    Add short history time for it. Wait until things get supported again and then remove history keeping again. It will store a little bit of data for a while, but it should be removed after you "do not keep history" again.
