Change per second preprocessing gives nonsense values
  • tikkami
    • May 2018
    • 71
    Case in short:
    I'm getting randomly false positive problems from switchport utilization. Item value could be 10Tbps on 100M port. I'm using 1m polling cycle.
    I have been looking the same oid with snmpget from switch. Counter values seems to grow steady, but still Zabbix gives enormous values sometimes.
    Items has not anything special... If[in|out]hcoctects with 2 preprocessing steps: change per second and custom multiplier 8.
    After the peak one polling cycle is always lost. Like this:
    00:00.10 5000 <normal value>
    00:01.10 5000000000
    00:02.10 <lost>
    00:03.10 4550 <normal value>
    Setup:
    Debian 10 VM, 2C/4GB RAM
    Zabbix 5.0.10
    MySQL
    ~100NVPS
    Any thoughts what could cause this?
    I have seen some slow queries from zabbix_server log. After optimizing of history tables, slow queries does not appear anymore. Could it still be performance issue with database?
  • alexlh
    • Feb 2022
    I'm having the same issue. Anyone any idea?
    • tikkami
      • May 2018
      • 71
      This same issue has been discussed in another thread
      It seems that turning off bulk requests helps at some cases.
