Zabbix Proxy Can't open PID File : Operation not permitted
  • sirbank
    • Jan 2022
    • 20
Name:	Screenshot 2022-03-02 175137.jpg
    • 5004
    selinux?
    file permissions... ?
    I kind of remember similar topic from recent weeks, but cannot remember any resolution...
    • um3n
      • Aug 2021
      • 48
      Hey sirbank!
      90% of errors on linux are wrong permissions :-)
      Please have a look in selinux or apparmor configuration and check whether that is blocking the access or creating of the pid file.
      • Robert N.
        • Feb 2022
        • 28
        always look into the log -
        sudo cat /var/log/zabbix/zabbix_proxy.log
        • sirbank
          • Jan 2022
          • 20
          Can you please tell me how to do it?
          Originally posted by um3n
          Hey sirbank!
          • um3n
            • Aug 2021
            • 48
            Did you checked the logfiles? Especially
            • audit logs
            • secure logs
            • zabbix logs
            If SELinux is disabled, then it should not interfere. Therefore it would be great to see the logfiles
            • NgRox
              • Jun 2022
              • 45
              My case...
              ERROR - Zabbix Proxy Can't open PID File : Operation not permitted
              Analisy
              tail -f /var/log/zabbix/zabbix-proxy.log
              ERROR - Cannot Create Database
              Edit zabbix-proxy.conf
              Edit parameter DBName=zabbix_proxy to DBName=/opt/zabbix/zabbix_proxy (If your configuration file is in /etc, then do it in /etc.)
              • um3n
                • Aug 2021
                • 48
                Originally posted by NgRox
                My case...
                Analisy
                I would say, this is your problem. The service could not create a database... maybe due to permissions or so..
                What db backend are you using? Why should you use "/opt/zabbix/zabbix_proxy" as DB name?
                • NgRox
                  NgRox commented
                  I resolved this.
                  Basically, the parameter was written as just zabbix_proxy instead of the path, so I couldn't create the database... I passed the path and then it was created.
                • 5004
                I would say sqlite3.
                • um3n
                  um3n commented
                  you are totally right should be sqlite3
