MariaDB 10.1 to MariaDB 10.6
  • Haija
    • Mar 2021
    Hello together
    I am trying to upgrade the database server from 10.1 to 10.6 in preparation for the upgrade to Zabbix 6.0.
    No errors in /var/log/mysql/error.log
    Found in /var/log/zabbix/zabbix_server.log:
    15198:20220329:135758.921 current database version (mandatory/optional): 05040000/05040001
    15198:20220329:135758.921 required mandatory version: 05040000
    Now I get the following error:
    Zabbix Server Version: 5.4.11
    Ubuntu 20.04 LTS
    Any help warmly welcome
    Haija
  • tim.mooney
    • Dec 2012
    • 1436
    Based upon the information you've provided, I can't tell what you did as part of the backend database migration from 10.1 to 10.6, so it will mostly be guesses about what the problem is.
    Did the database server hostname or IP address change as part of the migration? If so, did you update the front-end web interface config/zabbix.conf.php file with the updated host/IP and any other database connection changes?
    • Haija
      • Mar 2021
      Hello Tim
      Sorry for my late reply.
      Thanks for your reply and time.
      No, I have not changed the IP.
      I have one server running both Zabbix and mariadb.
      Based on your answer it should be no problem to upgrade directly from 10.1 to 10.6?
      Or does it need adjustments to the database?
