Discovery Rule Action adding ZBX agent when only SNMP is chosen
  • zhazell
    • Apr 2022
    • 17
    I cannot figure out how to make the discovery rule and discovery rule actions to not create the host with the ZBX agent. They are only monitored by SNMP and don't want the Zabbix agent status to show as it says unavailable. How do I tell the discovery rule/action to add the host with SNMP only?
Name:	Screen Shot 2022-04-26 at 1.57.56 PM.png
    Discovery Rule:
Name:	Screen Shot 2022-04-26 at 3.24.29 PM.png
    Rule Actions:
Name:	Screen Shot 2022-04-26 at 3.25.41 PM.png
Name:	Screen Shot 2022-04-26 at 3.25.46 PM.png
    • 4996
    Sounds like you have an item somewhere what checks agent availability? If you only have SNMP checks, that ZBX should never light up...
    • zhazell
      • Apr 2022
      • 17
      I only have a template applied to it, which is an SNMP template. I don't see any items on that template that is checking for agent availability. I agree, it doesn't light up, but causing the availability widget to show as unknown status. Trying to get a clean display of information.
Name:	Screen Shot 2022-04-27 at 8.19.01 AM.png
