Zabbix Upgrade PHP 7.2 to PHP 7.4 or 8.0
  • eryunl
    • Jun 2022
    Hello all,
    I have use zabbix version 6.0. It comes with an php version 7.2.24. However php version is not supported and it may cause vulnerability issues.
    I would like to upgrade it from 7.2 to 7.4(support ends of january of 2023) or 8.0(php 8.0 is not supported on zabbix 6.0). I do research but i have' nt found any documentation.
    Have you any guidance how to do it and would you suggested to wait new zabbix version 6.2? Thanks in advance​​​​​​​
  • Markku
    • Sep 2018
    • 1790
    Upgrading or installing PHP is not a function of Zabbix but it depends on your operating system. What is your OS and version?
    Markku
    • eryunl
      • Jun 2022
      I use centos 8 stream. Upgrading PHP does not effect on zabbix frontend?
      • Markku
        • Sep 2018
        • 1790
        If your PHP is a supported version and you have installed and configured it correctly, Zabbix frontend is happy.
        I don't know CentOS much but here is one instruction: https://www.server-world.info/en/not...am_8&p=php&f=3
        Markku
        • eryunl
          • Jun 2022
          Ok I' ll try this. Thank you!
