VMware Guests are not discovered (VMware vCenter, Zabbix 3.0)
  • yves.vogl
    • Feb 2016
    I did a clean install of Zabbix 3.0 on CentOS 7 64-Bit from RPM to test VMware guest discovery.
    I adjusted the zabbix_server.conf as following:
    StartVMwareCollectors=2
    VMwareFrequency=60
    VMwarePerfFrequency=60
    VMwareCacheSize=2G
    VMwareTimeout=30
    I added 2 different vCenter installations as outlined in the current documentation:
    - Create a host
    - Link template "Template Virt VMware" to it
    - Set host macro for $URL (https://<fqdn>/sdk), $USERNAME and $PASSWORD
    After increasing the log level for the VMware collector (zabbix_server -R log_level_increase="vmware collector") I can see that there's a successful authentication and discovery ongoing:
     9047:20160219:212415.259 In vmware_service_update_perf() domain\username@https://<fqdn>/sdk
      9047:20160219:212415.259 In vmware_service_authenticate() 'domain\username'@'https://<fqdn>/sdk'
      9047:20160219:212415.485 End of vmware_service_authenticate():SUCCEED
    9048:20160219:212618.991 In wmware_vm_get_nic_devices()
      9048:20160219:212618.991 End of wmware_vm_get_nic_devices() found:1
      9048:20160219:212618.991 In wmware_vm_get_disk_devices()
      9048:20160219:212618.992 End of wmware_vm_get_disk_devices() found:2
      9048:20160219:212618.992 End of vmware_service_create_vm():SUCCEED
      9048:20160219:212618.992 In vmware_service_create_vm() vmid:'vm-236'
      9048:20160219:212618.992 In vmware_service_get_vm_data() vmid:'vm-236'
      9048:20160219:212618.998 End of vmware_service_get_vm_data():SUCCEED
      9048:20160219:212618.998 In wmware_vm_get_nic_devices()
      9048:20160219:212618.999 End of wmware_vm_get_nic_devices() found:1
      9048:20160219:212618.999 In wmware_vm_get_disk_devices()
      9048:20160219:212619.000 End of wmware_vm_get_disk_devices() found:2
      9048:20160219:212619.000 End of vmware_service_create_vm():SUCCEED
      9048:20160219:212619.000 End of vmware_service_create_hv():SUCCEED
      9048:20160219:212619.000 In vmware_service_create_hv() hvid:'host-255'
      9048:20160219:212619.000 In vmware_service_get_hv_data() guesthvid:'host-255'
      9048:20160219:212619.017 End of vmware_service_get_hv_data():SUCCEED
      9048:20160219:212619.025 In vmware_service_create_datastore() datastore:'datastore-256'
      9048:20160219:212619.027 End of vmware_service_create_datastore()
      9048:20160219:212619.027 In vmware_service_create_datastore() datastore:'datastore-257'
      9048:20160219:212619.028 End of vmware_service_create_datastore()
      9048:20160219:212619.030 In vmware_service_create_vm() vmid:'vm-264'
      9048:20160219:212619.030 In vmware_service_get_vm_data() vmid:'vm-264'
      9048:20160219:212619.035 End of vmware_service_get_vm_data():SUCCEED
      9048:20160219:212619.035 In wmware_vm_get_nic_devices()
      9048:20160219:212619.036 End of wmware_vm_get_nic_devices() found:1
      9048:20160219:212619.036 In wmware_vm_get_disk_devices()
      9048:20160219:212619.036 End of wmware_vm_get_disk_devices() found:1
      9048:20160219:212619.037 End of vmware_service_create_vm():SUCCEED
      9048:20160219:212619.037 In vmware_service_create_vm() vmid:'vm-263'
      9048:20160219:212619.037 In vmware_service_get_vm_data() vmid:'vm-263'
      9048:20160219:212619.041 End of vmware_service_get_vm_data():SUCCEED
      9048:20160219:212619.042 In wmware_vm_get_nic_devices()
      9048:20160219:212619.042 End of wmware_vm_get_nic_devices() found:1
      9048:20160219:212619.042 In wmware_vm_get_disk_devices()
      9048:20160219:212619.043 End of wmware_vm_get_disk_devices() found:2
      9048:20160219:212619.044 End of vmware_service_create_vm():SUCCEED
      9048:20160219:212619.044 In vmware_service_create_vm() vmid:'vm-262'
      9048:20160219:212619.044 In vmware_service_get_vm_data() vmid:'vm-262'
      9048:20160219:212619.048 End of vmware_service_get_vm_data():SUCCEED
      9048:20160219:212619.049 In wmware_vm_get_nic_devices()
      9048:20160219:212619.049 End of wmware_vm_get_nic_devices() found:1
      9048:20160219:212619.049 In wmware_vm_get_disk_devices()
      9048:20160219:212619.050 End of wmware_vm_get_disk_devices() found:1
      9048:20160219:212619.050 End of vmware_service_create_vm():SUCCEED
      9048:20160219:212619.050 In vmware_service_create_vm() vmid:'vm-261'
      9048:20160219:212619.050 In vmware_service_get_vm_data() vmid:'vm-261'
      9048:20160219:212619.055 End of vmware_service_get_vm_data():SUCCEED
      9048:20160219:212619.055 In wmware_vm_get_nic_devices()
      9048:20160219:212619.056 End of wmware_vm_get_nic_devices() found:1
      9048:20160219:212619.056 In wmware_vm_get_disk_devices()
      9048:20160219:212619.057 End of wmware_vm_get_disk_devices() found:3
      9048:20160219:212619.057 End of vmware_service_create_vm():SUCCEED
      9048:20160219:212619.057 In vmware_service_create_vm() vmid:'vm-260'
      9048:20160219:212619.057 In vmware_service_get_vm_data() vmid:'vm-260'
      9048:20160219:212619.062 End of vmware_service_get_vm_data():SUCCEED
      9048:20160219:212619.062 In wmware_vm_get_nic_devices()
      9048:20160219:212619.063 End of wmware_vm_get_nic_devices() found:1
      9048:20160219:212619.063 In wmware_vm_get_disk_devices()
      9048:20160219:212619.064 End of wmware_vm_get_disk_devices() found:2
    9048:20160219:212620.567 In vmware_service_get_vm_data() vmid:'vm-827'
      9047:20160219:212620.568 End of vmware_service_process_perf_entity_data() values:90
      9047:20160219:212620.568 In vmware_service_process_perf_entity_data() type:VirtualMachine id:vm-55377
      9047:20160219:212620.568 In zbx_vmware_service_get_perf_entity() type:VirtualMachine id:vm-55377
      9047:20160219:212620.568 End of zbx_vmware_service_get_perf_entity() entity:0x7f3dcf5abe78
      9047:20160219:212620.568 End of vmware_service_process_perf_entity_data() values:15
      9047:20160219:212620.569 In vmware_service_process_perf_entity_data() type:VirtualMachine id:vm-55598
      9047:20160219:212620.569 In zbx_vmware_service_get_perf_entity() type:VirtualMachine id:vm-55598
      9047:20160219:212620.569 End of zbx_vmware_service_get_perf_entity() entity:0x7f3dcf5bbd28
      9047:20160219:212620.569 End of vmware_service_process_perf_entity_data() values:13
      9047:20160219:212620.569 In vmware_service_process_perf_entity_data() type:VirtualMachine id:vm-55623
      9047:20160219:212620.569 In zbx_vmware_service_get_perf_entity() type:VirtualMachine id:vm-55623
      9047:20160219:212620.569 End of zbx_vmware_service_get_perf_entity() entity:0x7f3dcf5b8138
      9047:20160219:212620.570 End of vmware_service_process_perf_entity_data() values:13
      9047:20160219:212620.570 In vmware_service_process_perf_entity_data() type:VirtualMachine id:vm-55601
      9047:20160219:212620.570 In zbx_vmware_service_get_perf_entity() type:VirtualMachine id:vm-55601
      9047:20160219:212620.570 End of zbx_vmware_service_get_perf_entity() entity:0x7f3dcf5b89c8
      9047:20160219:212620.571 End of vmware_service_process_perf_entity_data() values:13
      9047:20160219:212620.571 In vmware_service_process_perf_entity_data() type:VirtualMachine id:vm-55606
      9047:20160219:212620.571 In zbx_vmware_service_get_perf_entity() type:VirtualMachine id:vm-55606
      9047:20160219:212620.571 End of zbx_vmware_service_get_perf_entity() entity:0x7f3dcf5bb498
      9048:20160219:212620.572 End of vmware_service_get_vm_data():SUCCEED
      9047:20160219:212620.572 End of vmware_service_process_perf_entity_data() values:16
      9047:20160219:212620.572 In vmware_service_process_perf_entity_data() type:VirtualMachine id:vm-55603
      9047:20160219:212620.572 In zbx_vmware_service_get_perf_entity() type:VirtualMachine id:vm-55603
      9047:20160219:212620.572 End of zbx_vmware_service_get_perf_entity() entity:0x7f3dcf5bca00
      9048:20160219:212620.572 In wmware_vm_get_nic_devices()
      9048:20160219:212620.573 End of wmware_vm_get_nic_devices() found:1
      9048:20160219:212620.573 In wmware_vm_get_disk_devices()
      9047:20160219:212620.573 End of vmware_service_process_perf_entity_data() values:20
      9047:20160219:212620.573 In vmware_service_process_perf_entity_data() type:VirtualMachine id:vm-55602
      9047:20160219:212620.573 In zbx_vmware_service_get_perf_entity() type:VirtualMachine id:vm-55602
      9047:20160219:212620.573 End of zbx_vmware_service_get_perf_entity() entity:0x7f3dcf5bac08
      9048:20160219:212620.573 End of wmware_vm_get_disk_devices() found:1
      9048:20160219:212620.573 End of vmware_service_create_vm():SUCCEED
      9048:20160219:212620.573 In vmware_service_create_vm() vmid:'vm-853'
      9048:20160219:212620.573 In vmware_service_get_vm_data() vmid:'vm-853'
      9047:20160219:212620.574 End of vmware_service_process_perf_entity_data() values:16
      9047:20160219:212620.574 In vmware_service_process_perf_entity_data() type:VirtualMachine id:vm-55618
      9047:20160219:212620.574 In zbx_vmware_service_get_perf_entity() type:VirtualMachine id:vm-55618
      9047:20160219:212620.574 End of zbx_vmware_service_get_perf_entity() entity:0x7f3dcf5b8580
      9047:20160219:212620.575 End of vmware_service_process_perf_entity_data() values:13
      9047:20160219:212620.575 In vmware_service_process_perf_entity_data() type:VirtualMachine id:vm-55267
      9047:20160219:212620.575 In zbx_vmware_service_get_perf_entity() type:VirtualMachine id:vm-55267
      9047:20160219:212620.575 End of zbx_vmware_service_get_perf_entity() entity:0x7f3dcf5ba378
      9047:20160219:212620.576 End of vmware_service_process_perf_entity_data() values:13
    But no hosts are beeing created at all…
     9048:20160219:212732.840 End of vmware_service_add_perf_entity() perfcounters:9
      9048:20160219:212732.840 End of vmware_service_update_perf_entities() entities:778
      9048:20160219:212732.840 End of vmware_service_update():SUCCEED
      9048:20160219:212732.840 __zbx_zbx_setproctitle() title:'vmware collector #2 [updated 2, removed 0 VMware services in 12.355428 sec, idle 5 sec]'
      9047:20160219:212732.877 __zbx_zbx_setproctitle() title:'vmware collector #1 [updated 0, removed 0 VMware services in 0.000002 sec, querying VMware services]'
      9047:20160219:212732.877 __zbx_zbx_setproctitle() title:'vmware collector #1 [updated 0, removed 0 VMware services in 0.000002 sec, idle 5 sec]'
      9048:20160219:212737.841 __zbx_zbx_setproctitle() title:'vmware collector #2 [updated 2, removed 0 VMware services in 12.355428 sec, querying VMware services]'
      9048:20160219:212737.841 __zbx_zbx_setproctitle() title:'vmware collector #2 [updated 0, removed 0 VMware services in 0.000002 sec, idle 5 sec]'
      9047:20160219:212737.878 __zbx_zbx_setproctitle() title:'vmware collector #1 [updated 0, removed 0 VMware services in 0.000002 sec, querying VMware services]'
      9047:20160219:212737.878 __zbx_zbx_setproctitle() title:'vmware collector #1 [updated 0, removed 0 VMware services in 0.000002 sec, idle 5 sec]'
      9048:20160219:212742.841 __zbx_zbx_setproctitle() title:'vmware collector #2 [updated 0, removed 0 VMware services in 0.000002 sec, querying VMware services]'
    The web interface does only show the zabbix server itself and both vCenter hosts.
    I cannot see anything happening in the inventory or in the MySQL database.
    Any help is greatly appreciated.
    Cheers,
    Yves
