Discard unchanged preprocessing fail
  • markfree
    • Apr 2019
    • 875
    I'm collecting some values from an application script and discarding when unchanged.
    Zabbix should save mostly 1 value per day, but it is storing the same value more than once.
    The item has a flexible interval and a preprocessing step, "Discard Unchanged", but still, it is saving repeated values.
    Click image for larger version  Name:	preprocessing.png Views:	0 Size:	5.9 KB ID:	448777
    Click image for larger version  Name:	flexible_interval.png Views:	0 Size:	4.5 KB ID:	448778
    Click image for larger version  Name:	values.png Views:	0 Size:	3.8 KB ID:	448779
    I'm trying to figure out why that is.
    Any idea?
  • Markku
    • Sep 2018
    • 1788
    What is your Zabbix version, are you running the latest release of the major version?
    When has the Zabbix server/proxy been restarted (maybe there is an in-memory dependency in this feature)?
    Markku
    • markfree
      • Apr 2019
      • 875
      It is version 6.2.1, the latest release.
      The last reboot was about a week ago.
      I'm not sure it will help, but I'll try rebooting the Proxys and servers.
      • Markku
        • Sep 2018
        • 1788
        Since you are "in the bleeding edge" you may want to open an issue in support.zabbix.com as well, and/or check the 6.2 series release notes if there is anything related.
        Markku
        • markfree
          • Apr 2019
          • 875
          Following your suggestion, I rebooted the environment and right after that a new value was collected by Zabbix.
          The latest value was the same, but it was not discarded.
          I'll open an issue with the support team.
          Thanks.
