Connection refused with simple checks
  • prh
    • Nov 2006
    I've just added a new host to my zabbix server, which I plan to monitor using only simple checks. However, zabbix-server says "Connection refused". I guess that's because I haven't installed zabbix-agent in those hosts.
    My question is: why does it say "Connection refused" if i'm only using simple checks?. Do I still have to install zabbix-agent in those hosts?. I thought that was the whole advantage of using simple checks (ie. not having to install zabbix-agent).
  • Alexei
    Founder, CEO
    • Sep 2004
    • 5654
    Simple checks do not require ZABBIX (or any) agent running on a monitored host. Make sure item type is set to "Simple Check" for simple checks.
    Alexei Vladishev
    New York | Tokyo | Riga
    My Twitter
    • prh
      • Nov 2006
      Thanks Alexei. That was the problem. I never changed the Item Type to "Simple check", I somehow thought that the item type was implicit when I select the item key. Anyway, to avoid this kind of problems it would be nice if the Select Item Key popup window would also set the Item Type field automatically.
      Great software by the way, keep up the good work!
