Installation issue | Packages missing zabbix-apache-conf' zabbix-sql-scripts
  • Acheron
    • Feb 2020
    Trying to install Zabbix Zabbix 6.0 LTS following the below URL: https://www.zabbix.com/download?zabb...ysql&ws=apache
    getting the below error:
    E: Package 'zabbix-apache-conf' has no installation candidate
    E: Unable to locate package zabbix-sql-scripts
    OS Details:
    root@monitor:~# lsb_release -a
    No LSB modules are available.
    Distributor ID:Ubuntu
    Description: Ubuntu 20.04.4 LTS
    Release: 20.04
    Codename: focal
    Tried updating the using: apt update
    it's up to date. All packages are up to date.
    Help is appreciated.
  • dimir
    Zabbix developer
    • Apr 2011
    • 1080
    In step 1 you need to select Ubuntu 20.04, not 22.04.
    • Acheron
      • Feb 2020
      Thanks, Dimir for the response;
      I believe you're referring to step 1 wget https://repo.zabbix.com/zabbix/6.0/u...u20.04_all.deb
      the same mentioned we are going, that is ubuntu20.04_all.deb
      • dimir
        Zabbix developer
        • Apr 2011
        • 1080
        Yeah, for some reason it sometimes is not changing the instructions on changing the filter. Try these instructions:
        wget https://repo.zabbix.com/zabbix/6.0/ubuntu/pool/main/z/zabbix-release/zabbix-release_6.0-3%2Bubuntu20.04_all.deb
        sudo dpkg -i zabbix-release_6.0-3+ubuntu20.04_all.deb
        rm zabbix-release_6.0-3+ubuntu20.04_all.deb
        sudo apt update​
        • MatiasCampo
          • Jun 2022
          I had a similar issue, and it had to do with the repo priority (I'm running a customized Ubuntu image). Run
          sudo apt-cache policy
          and make sure that the Zabbix repository has a higher priority than the Ubuntu ones. The Ubuntu repos have an old Zabbix distribution that does not include the zabbix-sql-scripts package.
          If it's your case too, you can change the priority of the repo by adding a file in /etc/apt/preferences.d similar to this:
          user@server:/etc/apt/preferences.d$ cat zabbix
          Package: *
          Pin: origin repo.zabbix.com
          Pin-Priority: 1000
