Zabbix 6.2: Inventory do not work as expected
  • andreagx
    • Oct 2021
    • 29
    We need a list of hosts and relative OS, so we have activated automatic inventory on all hosts.
    The fields is stil empty and only name of the host apperars.
    How can I get this data?
    PS the photo is about a Windows Server host
    thank you
    • 5004
    And which items are populating it? Automatic or not, if nothing is set to populate fields, then nothing appears there.
    • andreagx
      • Oct 2021
      • 29
      thank you for your reply.
      So, how can I set items to populate fields?
      Thank you
        • 5004
        There is checkbox in item config. https://www.zabbix.com/documentation...fig/items/item
        But you need to set your item to query for that specific data. It does not happen automagically..
        • andreagx
          • Oct 2021
          • 29
          Thank you for your answer and the sarcasm also :-)
          The item system.uname of the Zabbix Agent for Win is setted to write the value in the OS field... but the value is empty.
          Weird is I can get the value from the item configuration
Name:	Immagine 2022-09-23 190112.png
ID:	451823 Click image for larger version
Name:	Immagine 2022-09-23 185552.png
            • 5004
            Is not shown also in inventory page? on "Latest data" page? I am not completely sure, but as you have there "Discard unchanged with heartbeat" preprocessing, then yo might need to go back in time enough to see that last value...
            I'm not using default templates and inventory, so I have no place to check to be sure... And I don't have 6.2 also..
