Regular Expression in vfs.dir.count on windows agent seems not to work
  • amjelnes
    • May 2014
    I have an item with key:
    vfs.dir.count["E:\FSLogix",RW.VHDX,,,,20,,,86400,,@ExcludeRDSHXU sers]
    Referring to a regular expression:
    ^(xyz_.*|blabla.*) - Result is TRUE
    Now the item is reporting 2 files but those 2 files should be excluded as they are in dirs named "blabla_flhjl34l34h5l" and "xyz_dlfsahlahglago0ru087"
    I have tried putting the regular expression directly in the item, putting @ExcludeRDSHXUsers in there, and tried setting result both true and false in the regular expression..... item always reports 2 files.
    What am I doing wrong here?
    Tried searching for other posts, haven't found any that matches this one.
    Zabbix server version is 5.4.9
    Zabbix agent version is Zabbix Agent 2 5.4.9.2400
  • Answer selected by amjelnes at 10-10-2022, 12:10.
    cyber
    • 4996
    Global regexes do not work there.
    Theres "no" under "global regex".. for vfs.dir.count
    • amjelnes
      • May 2014
      Got it working by adjusting the regular expression and inserting it directly in the item key from:
      vfs.dir.count["E:\FSLogix",RW.VHDX,,,,20,,,86400,,^blabla_.*|^xy z_.*]
      to:
      vfs.dir.count["E:\FSLogix",RW.VHDX,,,,20,,,86400,,^(blabla_.*|xy z_.*)]
      But referencing the expression with @ does not seem to work.
        • 4996
        • amjelnes
          • May 2014
          Sort of explains it then ;-)
          Thanks for the reply and your time anyway :-)
