Trigger Action Message data issues (worked in 5.4, not in 6.2)
  • AdamDempsey
    • Mar 2021
    I recently upgraded from Zabbix 5.4 to 6.2 and I've read up about "Simple macros replaced by expression macros" in What's new in Zabbix 6.0.0.
    I had Telegram alerts sending when updates were available on both Windows and Linux servers, which included the list of available items, but since the upgrade that broke and it just included the number of updates (which is the trigger expression).
    I've tried various changes and added in other data and it all returns the number, am I going crazy or is this a bug?
    Trigger Message (with test items)
    Problem name: {TRIGGER.NAME}
    Trigger Expression: {TRIGGER.EXPRESSION}
    Trigger Value: {TRIGGER.VALUE}
    {ITEM.VALUE1} ({ITEM.NAME1})
    Processor load is: {?last(//system.cpu.load[,avg1])}
    {?last(//Winupdates.CritialList)}
    With the output of that being:
    LUXDEVRS02 - Updates Available
    Problem name: LUXDEVRS02 Updates Available
    Trigger Expression: last(/LUXDEVRS02/Winupdates.Critical)>0
    Trigger Value: 1
    3 (Critical Updates)
    Processor load is: 3
    3
    But winupdates.critiallist contains the text "* Update for Microsoft Office 2016 (KB5002243) 64-Bit Edition" and 3 is the value of Winupdates.Critical (I've been manually setting it vis Zabbix Sender for testing) and it seems to just return the 3 for anything, I'm sure that's not the average cpu load too!
    I hope that makes sense and someone can tell me what I'm doing wrong or if it looks like a bug.
    Thanks!
