Zabbix Proxy script fail - Segmentation fault
  • markfree
    • Apr 2019
    • 875
    I set up a Proxy 6.2 with ODBC for an Oracle DB.
    The connection is running and I can collect some data from the DB.
    I can test the connection using iSQL and it works fine at the command line.
    $ isql [dsn] [user] [pass] -b << EOF
    select count(*) from GENESYS_[dsn].TABLE;
    EOF
    | COUNT(*) |
    | 13
    $ isql [dsn] [user] [pass] -b <<< 'select count(*) from GENESYS_[dsn].TABLE;'
    | COUNT(*) |
    | 13
    Now, I wanted to execute manually that command from within Zabbix Frontend.
    For that, I created a script in Administration/Scripts with the same command.
    When I try to start the script upon an event, it fails with the following error.
    sh: line 1: 1654538 Segmentation fault (core dumped) isql [dsn] [user] [pass] <<< 'select count(*) from GENESYS_[dsn].TABLE;'
    The proxy log only shows the same error.
    1650390:20221014:120210.382 Failed to execute command "isql [dsn] [user] [pass] <<< 'select count(*) from GENESYS_[dsn].TABLE;'": sh: line 1: 1650690 Segmentation fault (core dumped) isql [dsn] [user] [pass] <<< 'select count(*) from GENESYS_[dsn].TABLE;'
    What would that be?​
  • satheshr90@
    • Feb 2023
    Hi, were you able to fix this issue? even we are facing same problem now after zabbix 5 to zabbix 6 environment.
    • markfree
      markfree commented
      I actually forgot about this post. It is fixed but I'll have to check that environment later.
  • aa-zabbix-user
    • Aug 2023
    Hello, if anyone has the fix to this issue "zabbix proxy script fail segmentation fault 6.2" please post it here as we are having this issue after upgrading from 5.2.2 to 6.2.9
    • markfree
      • Apr 2019
      • 875
      I have switched from iSQL to Oracle's SQLplus.
