Incorrect graph headers after upgrade from 5.0.30 to 6.0.12
  • rubanoid
    • Mar 2016
    • 12
    After upgrade from 5.0.30 to 6.0.12 some graph headers look like Zabbix shows variables instead of their values
    localhost CPU $2 time
    localhost free disk space on $1
    localhost Zabbix $4 $2 processes, in %
    Has anyone had a problem like this?​
  • Markku
    • Sep 2018
    • 1790
    Yes, see the upgrade notes for 6.0.0: https://www.zabbix.com/documentation...nger-supported
    You need to replace the positional macro "$N" with the "Nth" field in the key in the template, for example:
    system.cpu.util[,idle]: "CPU $2 time" -> "CPU idle time"
    Markku
    • MihaPik
      • Dec 2022
      Hello, you need replace $1 on the macros.
      • rubanoid
        • Mar 2016
        • 12
        Thanks a lot for you help.
        Do you happen to know whether it is possible to change all problem macroes at a time. I mean, is there any script to do that?
        If I upgrade Zabbix from 5.0.30 to 5.4.X and then to 6.0.12, will that help?
          • 5008
          No, no upgrade will change your item names. You need to change your templates after upgrade. I suppose those are all in prototypes, so one littel chaneg will affect many hosts..
