OpenSSL dependency error while installing 6.2 Agent on Cent OS 7
  • Bs_sousa
    • Dec 2022
    When I try to install the version 6.2 zabbix agent on a Cent OS 7 server I get the following errors
    --> Finished Dependency Resolution
    Error: Package: zabbix-agent-6.2.6-release1.el8.x86_64 (zabbix)
    Requires: libssl.so.1.1(OPENSSL_1_1_0)(64bit)
    Requires: libcrypto.so.1.1(OPENSSL_1_1_0)(64bit)
    Requires: libcrypto.so.1.1()(64bit)
    Requires: libssl.so.1.1(OPENSSL_1_1_1)(64bit)
    Requires: libssl.so.1.1()(64bit)
    You could try using --skip-broken to work around the problem
    You could try running: rpm -Va --nofiles --nodigest
    I updated the openssl version to v1.1.0f:
    >> openssl version
    OpenSSL 1.1.0f 25 May 2017​​
    The error remains.
    Anyone that can help?
    Thank you.​
