Setup.php does not respond
  • gferradas
    • Jan 2023
    • 24
    Hi im trying to install zabbix 6.0 on a RHEL 9 but at the time to check pre requisites the server stops responding and the logs in /var/log/httpd/error_log says something like this:
     AH01071: Got error 'PHP message: PHP Warning:  preg_match(): Compilation failed: unrecognised compile-time option bit(s) at offset 0 in /usr/share/zabbix/include/validate.inc.php(107) : eval()'d code on line 1PHP message: PHP Warning:  preg_match(): Compilation failed: unrecognised compile-time option bit(s) at offset 0 in /usr/share/zabbix/include/validate.inc.php on line 334PHP message: PHP Warning:  preg_match(): Compilation failed: unrecognised compile-time option bit(s) at offset 0 in /usr/share/zabbix/include/classes/validators/CApiInputValidator.php on line 521PHP message: PHP Warning:  Trying to access array offset on value of type null in /usr/share/zabbix/include/classes/validators/CApiInputValidator.php on line 522PHP message: PHP Warning:  Trying to access array offset on value of type null in /usr/share/zabbix/include/classes/validators/CApiInputValidator.php on line 523PHP message: PHP Warning:  preg_match(): Compilation failed: unrecognised compile-time option bit(s) at offset 0 in /usr/share/zabbix/include/classes/validators/CApiInputValidator.php on line 521PHP message: PHP Warning:  Trying to access array offset on value of type null in /usr/share/zabbix/include/classes/validators/CApiInputValidator.php on line 522PHP message: PHP Warning:  Trying to access array offset on value of type null in /usr/share/zabbix/include/classes/validators/CApiInputValidator.php on line 523PHP message: PHP Warning:  preg_match(): Compilation failed: unrecognised compile-time option bit(s) at offset 0 in /usr/share/zabbix/include/classes/validators/CApiInputValidator.php on line 521PHP message: PHP Warning:  Trying to access array offset on value of type null in /usr/share/zabbix/include/classes/validators/CApiInputValidator.php on line 522PHP message: PHP Warning:  Trying to access array offset on value of type null in /usr/share/zabbix/include/classes/validators/CApiInputValidator.php on line 523PHP message: PHP Warning:  preg_match(): Compilation failed: unrecognised compile-time option bit(s) at offset 0 in /usr/share/zabbix/include/classes/validators/CApiInputValidator.php on line 521PHP message: PHP Warning:  Trying to access array offset on value of type null in /usr/share/zabbix/include/classes/validators/CApiInputValidator.php on line 522PHP message: PHP Warning:  Trying to access array offset on value of type null in /usr/share/zabbix/include/classes/validators/CApiInputValidator.php on line 523PHP message: PHP Warning:  preg_match(): Compilation failed: unrecognised compile-time option bit(s) at offset 0 in /usr/share/zabbix/include/classes/validators/CApiInputValidator.php on line 521PHP message: PHP Warning:  Trying to access array offset on value of type null in /usr/share/zabbix/include/classes/validators/CApiInputValidator.php on line 522PHP message: PHP Warning:  Trying to access array offset on value of type null in /usr/share/zabbix/include/classes/validators/CApiInputValidator.php on line 523PHP message: PHP Warning:  preg_match(): Compilation failed: unrecognised compile-time option bit(s) at offset 0 in /usr/share/zabbix/include/classes/validators/CApiInputValidator.php on line 521PHP message: PHP Warning:  Trying to access array offset on value of type null in /usr/share/zabbix/include/classes/validators/CApiInputValidator.php on line 522PHP message: PHP Warning:  Trying to access array offset on value of type null in /usr/share/zabbix/include/classes/validators/CApiInputValidator.php on line 523PHP message: PHP Warning:  preg_match(): Compilation failed: unrecognised compile-time option bit(s) at offset 0 in /usr/share/zabbix/include/classes/validators/CApiInputValidator.php on line 521PHP message: PHP Warning:  Trying to access array offset on value of type null in /usr/share/zabbix/include/classes/validators/CApiInputValidator.php on line 522PHP message: PHP Warning:  Trying to access array offset on value of type null in /usr/share/zabbix/include/classes/validators/CApiInputValidator.php on line 523PHP message: PHP Fatal error:  Uncaught APIException: Invalid parameter "/output": value must be empty or one of "", "", "", "", "", "". in /usr/share/zabbix/include/classes/api/CApiService.php:887\nStack trace:\n#0 /usr/share/zabbix/include/classes/api/services/CSettings.php(108): CApiService::exception()\n#1 /usr/share/zabbix/include/classes/helpers/CSettingsHelper.php(104): CSettings->getGlobal()\n#2 /usr/share/zabbix/include/classes/helpers/CSettingsHelper.php(127): CSettingsHelper::loadParams()\n#3 /usr/share/zabbix/include/page_header.php(86): CSettingsHelper::getGlobal()\n#4 /usr/share/zabbix/include/validate.inc.php(371): require_once('...')\n#5 /usr/share/zabbix/include/validate.inc.php(431): invalid_url()\n#6 /usr/share/zabbix/setup.php(72): check_fields()\n#7 {main}\n  thrown in /usr/share/zabbix/include/classes/api/CApiService.php on line 887PHP message: PHP Warning:  Undefined array key "file" in /usr/share/zabbix/include/classes/debug/CProfiler.php on line 381PHP message: PHP Warning:  Undefined array key "line" in /usr/share/zabbix/include/classes/debug/CProfiler.php on line 381PHP message: PHP Warning:  Trying to access array offset on value of type null in /usr/share/zabbix/include/classes/core/CCookieSession.php on line 194'
    I followed the steps in https://www.zabbix.com/download?zabb...ysql&ws=apache if someone can help me i would appreciate it
  • tim.mooney
    • Dec 2012
    • 1437
    What version of PHP are you using? The first few releases in the 6.0.x series required PHP 7.2.5, 7.3.x, or 7.4.x, but not PHP 8.0. Recent Zabbix 6.0.x releases (6.0.6 and later, I think, check the documentation) now support PHP 8.0 and possibly PHP 8.1.
    • gferradas
      • Jan 2023
      • 24
      It seems like zabbix installed php-fpm 8.0 when i installed the packages how do i downgrade it to 7.2?
      • Markku
        • Sep 2018
        • 1790
        Requirements page (https://www.zabbix.com/documentation...n/requirements) says:
        PHP 7.2.5 or later,
        (since Zabbix 6.0.6) 8.0, 8.1
        Markku
        • gferradas
          gferradas commented
          yeah but later in 6.0 is 7.4 or is it up to php 8.0? because if 6.0 supports php 8.0 the problem still persists
      • Markku
        • Sep 2018
        • 1790
        It means: with Zabbix 6.0.0 - 6.0.5 you can use 7.2.5 or newer but 7.x series only, and with Zabbix 6.0.6 and later you can use 7.2.5 or newer up to and including 8.1.x.
        Markku
        • gferradas
          gferradas commented
          ok thanks i im gonna reinstall zabbix from scratch but use 7.2.5 instead if the problem still persists i let you know
