Creating alarms via web service with Zabbix
  • kerem.yarali
    • Sep 2019
    • 23
    We have a structure that creates an alarm by posting method with a web service. We want to convert this build to Zabbix. As far as I know, I think a similar integration can be done with Zabbix sender.
    I request your help on the matter.
  • medl
    • Nov 2022
    • 9
    What you describe is indeed true, also there is multiple different implementations and from what ive seen it is also not hard to implement even if you had to develop it yourself.
    • kerem.yarali
      • Sep 2019
      • 23
      Thanks medl. As far as I know, there is no need to have an agent installed for sender, isn't it enough just to have the sender package installed?
        • 5004
        yes.. sender does not require agent.
