AWS RDS instance by HTTP Template fails with "[ AWS RDS ] ERROR : 'hmac' undefined."
  • tw-lh
    • Jan 2023
    Attempting to use AWS RDS instance by HTTP Template fails with "[ AWS RDS ] ERROR : 'hmac' undefined." error
    I'm running 6.0.12 zabbix server and attempting to collect data from CloudWatch using the "AWS RDS instance by HTTP Template"
    The template get AWS RDS instance metrics and uses the script item to make HTTP requests to the CloudWatch AP
    I have read the README which seems straight forward.
    I have created a user and generated the access-key/secret pair and have updated the following Macros
    {$AWS.RDS.INSTANCE.ID}
    {$AWS.REGION}
    {$AWS.ACCESS.KEY.ID}
    {$AWS.SECRET.ACCESS.KEY}
    The IAM user policy is defined as the template requires.
    The result is no data is collected, and AWS IAM doesn't even report that the user has been used.
    The only log that I am seeing is
    [ AWS RDS ] ERROR: ReferenceError: identifier 'hmac' undefined
    Has anyone else seen success using this template?
  • tw-lh
    • Jan 2023
    Oh I didn't notice. It doesn't look like these templates were introduced until 6.0.13. That's my mistake.
    • cowsianyde
      • Aug 2023
      Hello tw-lh
      Did you solve the problem by upgrading your zabbix? I'm facing the same problem.
