Discovery by Proxy not working
  • Markku
    • Sep 2018
    • 1784
    #16
    Originally posted by ElementZero
    Well, I mean once I have the servers registered (whether I do it manually or use auto-registration) then the checks succeed using active checks. I haven't really tried passive
    That's your problem then: the discovery job tries to connect to the agent, so if you haven't allowed passive checks in the agent, the discovery cannot find anything.
    Markku
    • ElementZero
      • Jan 2021
      • 16
      #17
      FYI - I just tried to telnet from the proxy to a server on port 10050 and it worked fine
      • Markku
        • Sep 2018
        • 1784
        #18
        Well then, do you have an item agent.host configured and working on the agent?
        Markku
        • ElementZero
          • Jan 2021
          • 16
          #19
          That was it! I had to change it to agent.hostname and then it started working. Learning from that I set up a bunch of other things and everything is working great now with discovery. Thanks so much!
          • Test Subject
            Test Subject commented
            Hi I am having this same issue and nothing seems to work, I have followed this post but I seem to be having a little bit of misunderstanding, where and what did you change to agent.hostname to get the discovery to work?
