cannot write to IPC socket: Broken pipe
  • sic61
    • Jan 2023
    In my logs I have the message "cannot write to IPC socket: Broken pipe" which keeps coming back.
    After a while, I then get the following messages:
    zabbix_server [1717]: failed to open log file: [24] Too many open files
    zabbix_server [1717]: failed to write [cannot accept incoming IPC connection: [24] Too many open files] into log file
    and what causes the error "cannot send data to availability manager service"
    and therefore no more info from Zabbix agents among others.
    The Zabbix console is still available but without a force restart of the VM, no solution for a return to normal.
    Despite my research, no solution to this problem...
    Who could help me?
    Thanks​
    • 5004
    Too many open files... Try to increase the limit ... you can search for "too many open files in linux" and you get plenty of reading, what it means, and how to resolve it.
    • sic61
      • Jan 2023
      Hello, thank you for this feedback. I will look at this setting. Now does anyone know why I got the error "cannot write to IPC socket: Broken pipe"
      • Markku
        • Sep 2018
        • 1788
        In unix-style systems "everything" is a file, so fix the file limit first and then see if you have other problems as well.
        Markku
        • markosa
          • Aug 2022
          • 107
          Have you check'd this: Upgrading 3.4.7: [24] Too many open files] into log file - ZABBIX Forums​ ?
