Can not import map into zabbix
  • surgeon_2022
    • Apr 2022
    • 56
    Hi all,
    I am getting an issue with map importing on zbx 5.4.11
    Due to some reason I had to remove a map from the zabbix. Before that I created a backup using both methods xml and yaml.
    How I am trying to import that map back, however it stuck at loading step. I tried both of file but no luck
    I thought that the system is too busy and I tries to import map into zabbix 6.0 which is running on lab machine and got replica of the main DB. Still the same issue
    I do not see anything wrong in logs either.
    Any help is highly appreciated.
