Message is using unsupported protocol.
  • aidaitzabbix
    • Jan 2023
    • 12
    Hello folks,
    I'm monitoring a server called TEST with Zabbix agentv2. My Zabbix server version is 6.2
    I set up my Zabbix agent config file with the IP addresses of my new Zabbix server and my old Zabbix server version 3.2
    I would like to monitor my server TEST on both zabbix server meanwhile I finish the migration process, but looking the zabbixagent2 log file I get the following error from the ip address of the old Zabbix server
    failed to process an incoming connection from 10.20.20.4: Message is using unsupported protocol.
    How can I fix it? Thanks in advance.
  • Answer selected by aidaitzabbix at 24-03-2023, 15:32.
    aidaitzabbix
    • Jan 2023
    • 12
    Hello Atsushi,
    Thanks!!!
    • Atsushi
      • Aug 2013
      • 2028
      Do you mean you have configured Zabbix 6.2 agent to access Zabbix 3.2 Zabbix server? That combination is not supported. If Zabbix server is 3.2, use Zabbix agent version 3.2 or earlier.
      • aidaitzabbix
        • Jan 2023
        • 12
        Hello Atsushi,
        Thanks!!!
