SNMPv3 Trap on Docker Deployment
  • GetMeSomeCoffee
    • Jun 2022
    Hello everyone,
    I'm currently struggling with getting SNMPv3 traps to work.
    The deployment is completly dockerized and version 6.0.14 for the server-container and the snmp-container.
    SNMP traps v1 are working fine but v3 are not registered at all. v3 is running with authentication and privacy protocol (regular value collection working fine).
    I came across the following guide with some info about "engine id" but sadly I couldn't make out of it what i have to do in a containerized environment because the mentioned configuration are in a file that would not persist between containers: freedom and integrity of monitoring (zabbix.com)​
    Has someone else maybe run into the same issue and maybe solved it/found a workaround?
    Thank you.
  • _na_na_
    • Aug 2023
    Hi, i had the same problem and managed it.
    ( i believe there might be better solution...)
    first, I used net-snmp-create-v3-user command but it didn't work since it used "oldEnginID" of zabbix server itself.
    *you can see it in /var/lib/snmp/snmptrapd.conf
    however it is required that enginID of snmptrap sender.
    Then I updated /etc/snmp/snmptrapd.conf manually** and restarted container twice***.
    **createUser -e 0x8000000001020304 traptest SHA mypassword AES
    authuser log,execute traptest
    ***i don't know but just 1 time restart don't work
    This way is not for Docker container, but i have no other idea...
