User doesn't see actions
  • markuman
    • Mar 2023
    I've created with a super admin multiple actions.
    Two ldap users (both admin role) see different number of actions now.
    One sees not a single action, but the user is a member of the user group which will be notificated.
    The second user sees a few actions, but not all where the user is a member of the user group which gets notificated.
    Any idea what's wrong or what are the relations for actions to users?
  • sambhu.prakash
    • Apr 2021
    • 21
    Hey,
    Refer to Actions permissions - ZABBIX Forums and see if this is the same problem you are facing. If yes, try to use my solution mentioned there.
    Thanks.
