Missing items in zabbix-agent
  • vargaloid
    • Mar 2023
    Greetings!
    I have a strange issue with items.
    zabbix-agent2 doesn't know about different items, so it doesn't want to check the item.
    For instance, item 'net.if.in["eth0"]'
    There is no 'net.if.in[eth0]' in known items:
    root@zabbix:[~] # zabbix_agent2 -p | grep net.if.in
    net.if.in[lo,bytes] [s|153864064]
    root@zabbix:[~] #
    But:
    root@zabbix:[~] # zabbix_agent2 -t net.if.in["eth0"]
    net.if.in[eth0] [s|15373054196]
    root@zabbix:[~] #​
    And zabbix-server logs:
    2966107:20230405:124648.985 In get_value_agent() host:'hostname' addr:'127.0.0.1' key:'net.if.in["eth0"]' conn:'unencrypted'
    zabbix_agent2 (Zabbix) 6.0.15
    zabbix_server (Zabbix) 6.0.15
    Revision 287da69c170 31 March 2023, compilation time: Mar 31 2023 11:54:32​
    Does anyone know how to find the cause and fix the problem​?
  • Answer selected by vargaloid at 12-04-2023, 16:47.
    tim.mooney
    • Dec 2012
    • 1436
    Lot of other people that upgraded to 6.0.15 are experiencing similar problems, just look at some of the other threads in the past few days.
    • tim.mooney
      • Dec 2012
      • 1436
