Problem colecting bits and packets
  • ingrid@gearnoc.com.br
    • May 2022
    • 13
    Hi, I have a problem that i don't really know what to do. My hosts were coleting ok, but since 2 days ago everything related to packets just don't show.
    It show speed, Operational Status, etc, but bits received, bits sent, inbound packtes don't.
    I configured Zabbix 6.0 with Mysql. Try restarting both of them didnt work either​
  • solution
    • Jun 2020
    • 272
    Windows?
    In my cases this happened after updating the agent on the station.
    as Windows uses WMI/performance monitor the solution is to reset the WMI database.
    in CMD type: lodctr /R​
    Wellington
    • Atsushi
      • Aug 2013
      • 2028
      Are you using Zabbix 6.0.15? If you're using 6.0.15, it's a bug. Either use 6.0.14 or wait until a fixed version is released.
        • May 2022
        • 13
        Sorry for the late reply, but the problem was indeed the version. Downgrade to 6.0.14 and it works fine.
        I saw that they fixed it in 6.0.16 also.
