Issue logging in using Active Directory authentication
  • Goreandor
    • May 2023
    I have configured LDAP authentication using Active Directory, logs and matches groups successfully when testing. But when I try to actually log in with the same user, it fails with "Incorrect user name or password or account is temporarily blocked." error. Running Zabbix 6.4:
    I have double and triple-checked that I am inputting the correct login information and the account is certainly not blocked. Appreciate any pointers on anything that I am missing.
  • evaldoprestes
    • Jun 2016
    I had the same problem, the solution was change Host field value like this:
    Before: 192.168.32.5
    After: ldap://192.168.32.5​
    • Goreandor
      • May 2023
      Apologies for the late reply. Had a horrible week. I believe I did try that. I will check again though as soon as I can.
      • Arnold Kuehnle
        • May 2023
        Aftern reading further i found the solution:
        Using memberOf and leaving the "Group Name Attribute" empty did the job.
        Tested nested groups: does not work, only direkt membership of the users.
        ​ Click image for larger version
Name:	Screenshot 2023-05-16 183944.png
